Renthall 758 ultra low bars - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Renthall 758 ultra low bars (/showthread.php?tid=81822) |
Renthall 758 ultra low bars - steve65 - 01-07-20 I’ve researched replacement bars as I’m used to a wider slightly straighter bar on my Guzzi Griso and I Had Ultra Lows on my old ZRX1200R so that’s the direction I’m going in. I won’t be near my bike for a couple of weeks but want to order the bars. As they are a little straighter can anyone who’s done this swap tell me if there’s any possibility with a fairing clash or is there plenty of space. Ta much. Re: Renthall 758 ultra low bars - robbo - 01-07-20 Hi Steve, I’d say that the 758’s are the most popular choice, and there are no issues with clearance, and I have mine pushed quite far forward. If you want to keep the original bar end weights, which are quite heavy (308grams) compared to aftermarket ones, you’ll need to get the bar ends threaded as the stock Fazer ones screw in. The thread required would be 16mm@ 16 threads per inch. Re: Renthall 758 ultra low bars - PieEater - 01-07-20 (01-07-20, 05:10 PM)robbo link Wrote: Hi Steve, I’d say that the 758’s are the most popular choice, and there are no issues with clearance, and I have mine pushed quite far forward. If you want to keep the original bar end weights, which are quite heavy (308grams) compared to aftermarket ones, you’ll need to get the bar ends threaded as the stock Fazer ones screw in. The thread required would be 16mm@ 16 threads per inch.+1 on the above, getting the bars tapped out for the OEM weights is definately reccomended as they cut down considerably on vibration through the bars. Re: Renthall 758 ultra low bars - steve65 - 01-07-20 Thanks a lot fellas. I’ll be doing that. Robbie, is that a 16mm diameter tap? If I’m correct that equates to 5/8 when looking for a tap? I started school with imperial but by the time I left it was metric! Cheers Steve Re: Renthall 758 ultra low bars - robbo - 01-07-20 Yep, a 16mm tap. The inside diameter of the Renthals is 14mm. When mine were done I was told it was necessary to run a 15mm drill in the bar end first. Others have proved since that this is unnecessary so the bar can be tapped directly. When I started school it was imperial, and when I left school.....it was still imperial :lol . Re: Renthall 758 ultra low bars - steve65 - 02-07-20 Thanks a lot. I best get ordering! Re: Renthall 758 ultra low bars - steve65 - 02-07-20 Ah, one more question. Do you know if it’s British Standard Whitworth or something else? Re: Renthall 758 ultra low bars - robbo - 02-07-20 All my whitworth stuff and AF for that matter, have been confined to a metal box under my workbench, no doubt never to see the light of day again. All I know is the thread required is 16mm at 16tpi. If you remove a bar end weight, you'll need an allen key for that, you'll be able to measure the thread and see what's required. Re: Renthall 758 ultra low bars - steve65 - 02-07-20 That’s great. Cheers Robbo. I appreciate all the info. Re: Renthall 758 ultra low bars - teecee90 - 02-07-20 You need an M16x2 tap https://www.ebay.co.uk/itm/M16-x-2-HSS-Tap-Right-Hand-Ground-Thread-Straight-flute-TJ/254195866152?hash=item3b2f411a28:g:ukgAAOSw2GlXJgJd Re: Renthall 758 ultra low bars - steve65 - 04-07-20 (02-07-20, 02:33 PM)teecee90 link Wrote: You need an M16x2 tap That’s great. Thanks a lot. RE: Renthall 758 ultra low bars - fazerscotty - 16-07-24 (04-07-20, 04:53 PM)steve65 Wrote:(02-07-20, 02:33 PM)teecee90 link Wrote: You need an M16x2 tap That doesn't work - trust me I've tried. M16 x 1.5 does however. For Sale - M16 x 2 Tap. Used once (in error). |
