wanted fzs 600 fork spacer and damper 2002 on.. - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: wanted fzs 600 fork spacer and damper 2002 on.. (/showthread.php?tid=81774) |
wanted fzs 600 fork spacer and damper 2002 on.. - cl1ve2004 - 15-06-20 As said in subject, going to change forks back to standard as they've been modded to take emulators. Need the top spacer (183mm long) and damper. Cheers Cl1ve Re: wanted fzs 600 fork spacer and damper 2002 on.. - ArchDruid - 18-06-20 I assume you're talking about the internal spacer just underneath the fork cap ? I've made up these spacers before from aluminium tube. Not difficult, if you can find suitably sized tube with OD/ ID close to what you need. What are the standard ID/ OD measurements for the 600 ? Re: wanted fzs 600 fork spacer and damper 2002 on.. - cl1ve2004 - 18-06-20 That's the one, I know it's 183mm long and I wrote the o/d and i/d down somewhere.. Good shout for using ally tube, I had thought about mild steel tube.. It's going to be the damper that's the problem I reckon.. Thanks for the info, I'll source some ally tube :thumbup :thumbup |
