gen 1 fazer notchy gear change - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: gen 1 fazer notchy gear change (/showthread.php?tid=81692) |
gen 1 fazer notchy gear change - seano - 20-05-20 hi my 05 is a bit "notchy " through the gears and clunks when selecting first, never slips out of gear just have to be positive foot movement any ideas???? Re: gen 1 fazer notchy gear change - old son - 20-05-20 Probably needs the chain adjusting correctly. Check the manual. It would also be a good idea to lubricate the linkages. Re: gen 1 fazer notchy gear change - seano - 21-05-20 thanks but i have done that Re: gen 1 fazer notchy gear change - bludclot - 21-05-20 The gen 1 is seems sensitive to clutch its cable, I think it's because it goes through 4 angles between lever and housing. Is yours a genuine cable? If so it will need to be adjusted 'just so' for a smooth change and an easy to find neutral. I and others on this forum have tried after market cables and have promptly changed them for genuine. Re: gen 1 fazer notchy gear change - celticbiker - 21-05-20 Make sure your shift lever pivot is clean and lubed too. My fz8 gets notchy when it's ready for a lube. Re: gen 1 fazer notchy gear change - seano - 22-05-20 (21-05-20, 07:23 AM)bludclot link Wrote: The gen 1 is seems sensitive to clutch its cable, I think it's because it goes through 4 angles between lever and housing. Is yours a genuine cable? If so it will need to be adjusted 'just so' for a smooth change and an easy to find neutral. I and others on this forum have tried after market cables and have promptly changed them for genuine. Re: gen 1 fazer notchy gear change - seano - 22-05-20 thanks il give that a go |
