Fazer 1000 gen 1 2005 wheels - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Fazer 1000 gen 1 2005 wheels (/showthread.php?tid=81690) |
Fazer 1000 gen 1 2005 wheels - Ripsnortingvtwin - 19-05-20 guys i have seen a few 1000 with 5 spoke wheels ( now i have the i wants ) any done this ? and can tell me what needed to convert i think its r1/r6 wheels any if you have done this please can you tell me whats needed thanksmike Re: Fazer 1000 gen 1 2005 wheels - Tmation - 19-05-20 I think the Gen 2 wheels fit with a little bit of fettling. I did look at this about 10 years ago but never bothered, so can't confirm one way or the other. I also seem to remember Devilsyam (RIP) telling me that to fit the R1 rear wheel you need to have a disc made up to fit. Have you been through the Gen 1 FAQ sticky on this forum? Hopefully someone will come along soon and give you the proper information. Re: Fazer 1000 gen 1 2005 wheels - NorthWestern - 19-05-20 Early R1 rear isn't a straight swap due to the disk offser and radius being different. I believe the later ones just need a different disk. I fit a 4xv one to mine but it requires work: http://foc-u.co.uk/index.php?topic=18950.msg222278#msg222278 Re: Fazer 1000 gen 1 2005 wheels - Red Ceri - 20-05-20 I fitted 2003 R6 wheels to my 2003 Gen1. Both wheels have the same rim size so tyre size is the same. front wheel is a straight swap, except for the discs, as the later Yam wheels are 5 disc bolt fitting rather than 6 as on the Gen 1s. Rear wheel takes the Gen 1 sprocket carrier and spacer so the left side of the rear wheel is OK. The Brake side needs some more thought and at least one extra wheel spacer. I ended up using a GEN 2 ABS rear caliper and carrier that I modified with a welded plate to match the Gen1 torque arm. I needed a different rear disc (again 5 vs 6 bolt fixing) and i think i ended up with a Gen 2 rear disc as well. Re: Fazer 1000 gen 1 2005 wheels - Ripsnortingvtwin - 20-05-20 thanks for this , i am going to do this over the winter as i found the old race bike wheels there off a 5sl 2005 |
