Stock shock spring dimensions - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Stock shock spring dimensions (/showthread.php?tid=81656) |
Stock shock spring dimensions - Fazero - 08-05-20 Hello, does anybody now the shock spring dimensions and spring rate of a 03 FZS 600? Thank you! Re: Stock shock spring dimensions - unfazed - 10-05-20 Page 2-10 of the service manual Re: Stock shock spring dimensions - Carpy - 10-05-20 Shock absorber travel 50mm Spring Free Length 177mm Fitting Length 168mm Spring Rate (K1) 147N/mm (14.7Kg/mm) Stroke (k1) 0 - 50mm Enclosed gas pressure 1200kpa (12kg/cm2) |
