FZ1 gen2 - Your running temp?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: FZ1 gen2 - Your running temp?? (/showthread.php?tid=81617) |
FZ1 gen2 - Your running temp?? - killerwhaleTRX - 21-04-20 So, today we had 18-19 degrees out and i did a 30 min inspired run after work. When stopping at home temp was 103 and both fans went on when cycling the ign. Where are your temps...?? I´m contemplating that the Lars MAP is to lean with a full system hence the high temp....!? Regards Mattias Re: FZ1 gen2 - Your running temp?? - Dudeofrude - 21-04-20 Mine depends on what sort of riding conditions I'm in. If I keep moving and am doing at least 30mph+ then mine sits around 78-80, even if I'm doing 100mph+ it sticks around that temp. If I'm stop-starting, waiting at lights or just in general slow traffic then the fans come on at 100 degrees which tends to happen after about 15-20mins In all honesty I can count one 1 hand the amount of times the fan has kicked in on mine in 4 years of ownership. I actually have to try and get it to kock in most of the time just to check it's still working haha Re: FZ1 gen2 - Your running temp?? - killerwhaleTRX - 21-04-20 (21-04-20, 08:35 PM)Dudeofrude link Wrote: Mine depends on what sort of riding conditions I'm in. That was kinda what i thought, have to go for a richer map. from the map pack..until i get the autotune in there. I where seldom under 100km/h in that half hour so way to hot! Thanks! Re: FZ1 gen2 - Your running temp?? - Dudeofrude - 21-04-20 Have you not got a local tuning shop that can run it up on a dyno for you? That would tell you instantly if your running too lean? What modifications have you done to make it run cleaner? Re: FZ1 gen2 - Your running temp?? - coffee - 21-04-20 When my bike's laid up for the winter I occasionally start it up until the fans kick in and it seems to take forever coming on at about 100 but what I've found is one comes on before the other and I sometimes don't wait for the 2nd one to start because I'm normally pissed off by now but I do know it works but just like you I don't think I've noticed them on on a run,I suppose if you sat in a traffic jam in the summer they'd come on but why wouldn't you be filtering ? :lol
Re: FZ1 gen2 - Your running temp?? - killerwhaleTRX - 22-04-20 (21-04-20, 08:48 PM)Dudeofrude link Wrote: Have you not got a local tuning shop that can run it up on a dyno for you? That would tell you instantly if your running too lean? As said, full exhaust system straight thru no dB killer...opened up airbox with BMC filter. Re: FZ1 gen2 - Your running temp?? - killerwhaleTRX - 24-04-20 So, i put in wittlebeast smoothed stage 4 tune and not only did it ran smoother and easier throttle control. In high speed temp was 75-80 degrees & in slow traffic it maxed out at 93 degrees. Well happy with that!! A sidenote.....As a former TRX owner with a TDM900 motor in it. It´s the same thing with this engine. If one is not using earprotection you hear the motor and wonder if they used spanners for motoroil. Plugs in and you only hear the exhaust note, relax more and just thrash it as it should be ridden. |
