Poor starting - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Poor starting (/showthread.php?tid=81575) |
Poor starting - Wizard9956 - 07-04-20 Hi, I bought my fzs600 2003 a few months ago with 13,800 miles on the clock, it was running poorly at low speed so I stripped and cleaned the carbs , and it then ran much better. Lately I’ve started having trouble starting from cold , it doesn’t fire straight away on no3 cylinder ( cold exhaust header ), after about 30 seconds of rough running no3 warms up and idles perfectly, and rides perfectly. Has anyone had this sort of fault , I’m tempted to blame the carb idle circuit, but shouldn’t it run poorly when warmed up too. Any ideas great fully received. Cheers Wiz Re: Poor starting - BBROWN1664 - 07-04-20 Do you use the choke? Re: Poor starting - redmandan - 07-04-20 No 3 is a problem cylinder on my bike as well as many of the other guys on here. Problems can be but are not limited to:
Re: Poor starting - Wizard9956 - 07-04-20 [size=1.35em]Thanks for the info , gives me some things to check . Will take a look at the drain holes [/size] [size=1.35em]and try swapping the leads and see if the fault changes cylinder, although it runs well once warm , it is becoming a pain to start . I do sometimes try using the choke , it’s a bit of a lottery , it either starts and revs as expected or it floods, it’s the same with half choke . Cheers Wiz [/size] Re: Poor starting - Wizard9956 - 07-04-20 Sorry about the text size , got a small phone and big fingers Re: Poor starting - darrsi - 07-04-20 Is the battery in a good state, or could it need a boost? Shouldn't need to use the choke at all in this warmer weather. Re: Poor starting - Gnasher - 08-04-20 (07-04-20, 06:31 PM)Wizard9956 link Wrote: I stripped and cleaned the carbs , and it then ran much better. There is your problem, it's crab related. (07-04-20, 06:31 PM)Wizard9956 link Wrote: Has anyone had this sort of fault , I’m tempted to blame the carb idle circuit, but shouldn’t it run poorly when warmed up too. No, if it's running fine when warmed up. (07-04-20, 06:31 PM)Wizard9956 link Wrote: Any ideas great fully received. Providing the bikes running fine in all other respects, the issue is the cold start plunger on No3 crab. Check that it's moving freely over all it's travel, that the link fork is correctly fitted in the plunger shaft rebate, or not bent/damaged. These are almost never serviced, became dry and seize over time, there's a fair bit of play in the linkage/opening fork they can stick shut, choke effect doesn't work poor starting, or half open poor running at low revs when warm but fine higher revs. The plunger unscrews as an assembly, often just a clean very light smear of grease and its sorted, that said they can suffer oxidisation of the plunger bore, this will need to be removed. Re: Poor starting - grahound - 08-04-20 Just a correction coils do 1+42+3 Re: Poor starting - Gnasher - 08-04-20 (08-04-20, 06:20 PM)grahound link Wrote: Just a correction coils do 1+42+3 Lost me ???? Re: Poor starting - grahound - 08-04-20 Typo , coils are cyl 1 + 4 2 + 3 not 1+3 dont want to mix up leads. Re: Poor starting - Gnasher - 08-04-20 Still lost, this issue got nothing to do with coils. Re: Poor starting - darrsi - 09-04-20 (08-04-20, 08:21 PM)Gnasher link Wrote: Still lost, this issue got nothing to do with coils. Because earlier in the post it was suggested to swap 1 + 3 HT Leads. So i'm guessing if the coils feed 1 + 4 and the other 2 + 3, then the bike isn't going to be too happy about things if you swap 1+ 3 over? Re: Poor starting - BBROWN1664 - 09-04-20 IF coil #2 which feeds cylinder 2&3 is failing, you will have issues with both cylinder #2 and #3. As such, as it is only cylinder #3 that has the issue, it is not the coil that is playing up but could be the individual plug or lead to #3 or more likely a fuel/air issue with #3. Re: Poor starting - Gnasher - 09-04-20 (09-04-20, 05:24 AM)darrsi link Wrote: [quote author=Gnasher link=topic=26055.msg312101#msg312101 date=1586373673] Because earlier in the post it was suggested to swap 1 + 3 HT Leads. So i'm guessing if the coils feed 1 + 4 and the other 2 + 3, then the bike isn't going to be too happy about things if you swap 1+ 3 over? [/quote] If it was the coils the bike wouldn't run when warmed up. It's not anything to do with the ignition circuit
Re: Poor starting - darrsi - 09-04-20 (09-04-20, 10:31 AM)Gnasher link Wrote: [quote author=darrsi link=topic=26055.msg312129#msg312129 date=1586406274] Because earlier in the post it was suggested to swap 1 + 3 HT Leads. So i'm guessing if the coils feed 1 + 4 and the other 2 + 3, then the bike isn't going to be too happy about things if you swap 1+ 3 over? [/quote] If it was the coils the bike wouldn't run when warmed up. It's not anything to do with the ignition circuit [/quote] I'm just pointing out the answer to your earlier confusion. Re: Poor starting - Gnasher - 09-04-20 (09-04-20, 10:35 AM)darrsi link Wrote: I'm just pointing out the answer to your earlier confusion. Yes mate. I'm just trying to stop people sending this chap up blind allies and potentially wasting money :rolleyes Re: Poor starting - BBROWN1664 - 09-04-20 Sounds like it probably just needs a good service. When was the last time it was given some real TLC? Change the plugs and air filter. Balance the carbs and reset the TPS. Re: Poor starting - darrsi - 09-04-20 (09-04-20, 10:44 AM)Gnasher link Wrote: [quote author=darrsi link=topic=26055.msg312141#msg312141 date=1586424953] Yes mate. I'm just trying to stop people sending this chap up blind allies and potentially wasting money :rolleyes [/quote] :thumbup |
