Rear Brake refurb - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear Brake refurb (/showthread.php?tid=81547) |
Rear Brake refurb - fazersharp - 29-03-20 I was going to change pads and fluid and line after my MOT in April - after the MOT in case I potatoed the caliper. I now have anextra 6 months so am doing now. I have read the various posts and advice but thought I would start my own as I have a few questions.I will be using a hel line and on the website it mentions black stealth heat shrink on the ends as an option. I actually think it looks a bit messy and my new line will be clear stainless steel but on the rear is there any reason to have the "stealth heat shrink.
Re: Rear Brake refurb - Gnasher - 29-03-20 (29-03-20, 03:26 PM)fazersharp link Wrote: I have a few questions.I will be using a hel line and on the website it mentions black stealth heat shrink on the ends as an option. I actually think it looks a bit messy and my new line will be clear stainless steel but on the rear is there any reason to have the "stealth heat shrink. No it's purely cosmetic. (29-03-20, 03:26 PM)fazersharp link Wrote: Not really needed it's up to you 7mm x 1mm pitch. You can do the job with 250ml if you don't waste it. DOT 4 you don't need anything else. SBS HF ceramic is what you need, they are OE equivalent. Go for Flowers, for the rear seals, you can buy a kit which includes the pistons & seals, or you can but each separate. All depends how bad the pistons are. If you're going to split the caliper body you will need a body seal, you can't get this from Yamaha, Suzuki's GS500 one fits perfectly. Re: Rear Brake refurb - vinnyb - 29-03-20 Or you could try Fowlers if the flowers don't work :lol Re: Rear Brake refurb - fazersharp - 29-03-20 Thanks for your help (29-03-20, 05:30 PM)Gnasher link Wrote: Not really needed it's up to you 7mm x 1mm pitch.
And a basic question do I pop the pistons out then take the seals out and clean in and around their seats, replace with new then push the cleaned and inspected pistons back in. I will be taking the caliper off and doing it on a bench.Do I need to do anything with the master cylinder. Re: Rear Brake refurb - fazersharp - 29-03-20 Any recommendations as to where to get the pads. Re: Rear Brake refurb - darrsi - 29-03-20 (29-03-20, 07:41 PM)fazersharp link Wrote: Any recommendations as to where to get the pads. Don't worry about the year, they'll fit. http://www.bits4motorbikes.co.uk/brakes/MotorBikeBrakePadsAndShoes.html?MotorbikeID=6368 Re: Rear Brake refurb - Gnasher - 29-03-20 (29-03-20, 07:36 PM)fazersharp link Wrote: Yes, if you think you'll shear them, but you don't need stainless. In most case the weep because people over tighten them and bugger the seat in the caliper buying new nipples will have little effect. The rear pistons don't fair well and in most cases need replacing, only by inspection can you tell, but if you've not got them and yours are shot you've got to wait and reorder, that costs more. Your choice. All depends how you get the pistons out, these rears can be a real pain to remove even with hydraulic pressure. Often the only way is to split the caliper and twist them out, that can't be done with the caliper whole but you run the risk of damaging the pistons, if damaged enough the can't be reused. If you split it and you've not got the seal, you run the risk of it leaking should you reuse it, it will leak. Re: Rear Brake refurb - fazersharp - 29-03-20 Thanks Gnasher, before you posted I was looking at the price difference and it's only 26 quid exta for the kit with with pistons. So I can be as rough as I need to be in getting the old ones out. Just to confirm that I pop them out without splitting the caliper Re: Rear Brake refurb - fazersharp - 29-03-20 (29-03-20, 08:25 PM)darrsi link Wrote: [quote author=fazersharp link=topic=26027.msg311393#msg311393 date=1585507294]thanks for the link. These ones then SBS STREET 570HF Ceramic Don't worry about the year, they'll fit. http://www.bits4motorbikes.co.uk/brakes/MotorBikeBrakePadsAndShoes.html?MotorbikeID=6368 [/quote] Re: Rear Brake refurb - darrsi - 29-03-20 (29-03-20, 09:05 PM)fazersharp link Wrote: [quote author=darrsi link=topic=26027.msg311394#msg311394 date=1585509914]thanks for the link. These ones then SBS STREET 570HF Ceramic Don't worry about the year, they'll fit. http://www.bits4motorbikes.co.uk/brakes/MotorBikeBrakePadsAndShoes.html?MotorbikeID=6368 [/quote] [/quote] https://www.sbs.dk/products-1/brake-pads/570hf Re: Rear Brake refurb - Fazerider - 30-03-20 If you’ve avoided wet and salty roads it’s a fair bet that the pistons will be fine. I've never needed to split calipers... i see which piston moves easier then use a small G-clamp to hold it in while using the pedal to pump the difficult one out. Then piston pliers to wriggle the other out. If the seals on the master cylinder haven’t been replaced recently I’d change ‘em. Yamaha say to do so every 4 years for all the hydraulics’ rubber components, though that is a bit over-cautious. You can avoid problems with bleed nipples by greasing the threads when you put them in. And a squirt of WD40 down the hole after bleeding blows out that nasty hygroscopic brake fluid... just keep your face out of the firing line when you do.
Re: Rear Brake refurb - Gnasher - 30-03-20 (29-03-20, 09:01 PM)fazersharp link Wrote: Thanks Gnasher, before you posted I was looking at the price difference and it's only 26 quid exta for the kit with with pistons. So I can be as rough as I need to be in getting the old ones out. :thumbup (29-03-20, 09:01 PM)fazersharp link Wrote: If you've not got piston pliers, be sure to leave enough of the second piston proud of the caliper body that you can grip it. These pistons are quite long and you need to push which ever one you're not taking out back into the body, just make sure you do as above or you'll have to get hold of piston pliers to remove it. Push them both out with a single pad between them, get them a equal as possible, now clean the pistons ensure you get to the undersides, grease them and push them back. This will help free them, it will also give you an indication if they're seized, from there you can decide to split or not. As mentioned these are often a real pain to remove and they can lock themselves in, I've had many an owner turn up with a caliper body with chewed up seized pistons. :wall If your's have been well maintained your should be ok, good luck. Re: Rear Brake refurb - fazersharp - 30-03-20 (30-03-20, 12:18 AM)Fazerider link Wrote: If you’ve avoided wet and salty roads it’s a fair bet that the pistons will be fine. I've never needed to split calipers... i see which piston moves easier then use a small G-clamp to hold it in while using the pedal to pump the difficult one out. Then piston pliers to wriggle the other out.Good tips thanks. Think I will invest in a pair of piston pliers. No rain or salt in 19 years . Which seals is it in the master cylinder I cant tell in the fowlers exploded diagram.
Re: Rear Brake refurb - fazersharp - 30-03-20 (30-03-20, 09:06 AM)Gnasher link Wrote: If you've not got piston pliers, be sure to leave enough of the second piston proud of the caliper body that you can grip it. These pistons are quite long and you need to push which ever one you're not taking out back into the body, just make sure you do as above or you'll have to get hold of piston pliers to remove it.Thanks for your help. Will be getting some piston pliers. I wouldn't say the rear caliper has been "well looked after" other than keeping is clean but doesn't really get dirty.So before I take off completely I will use the pedal to push them out to grease them. Are they long enough to push out until they touch each other or maybe a thin piece of metal in-between so I can use it to push them apart after greasing.Thinking if I buy the set with new pistons and mine are ok I could sell the new pistons on their own. Re: Rear Brake refurb - Gnasher - 30-03-20 (30-03-20, 12:00 PM)fazersharp link Wrote: Are they long enough to push out until they touch each other or maybe a thin piece of metal in-between so I can use it to push them apart after greasing. As stated above "Push them both out with a single pad between them, get them a equal as possible" Re: Rear Brake refurb - Fazerider - 30-03-20 (30-03-20, 11:51 AM)fazersharp link Wrote: [quote author=Fazerider link=topic=26027.msg311411#msg311411 date=1585523927]Good tips thanks. Think I will invest in a pair of piston pliers. No rain or salt in 19 years . Which seals is it in the master cylinder I cant tell in the fowlers exploded diagram. [/quote] Fowlers Item 6, the “Cylinder Kit, Master” is what I’ve bought in the past. It does include more than strictly needed, but I don’t think you can get the individual rubber parts separately. As you probably know, getting air out of the back brake is a pain because the path the fluid fluid takes goes up and down. Air trapped in the master cylinder is best removed by slackening the banjo at the top. Re: Rear Brake refurb - fazersharp - 30-03-20 (30-03-20, 01:44 PM)Fazerider link Wrote: Fowlers Item 6, the “Cylinder Kit, Master” is what I’ve bought in the past. It does include more than strictly needed, but I don’t think you can get the individual rubber parts separately.yeiks that's another 56 quid, how many parts of that number 6 are actually rubber that is to be replaced. Does anyone actually replace master cylinder parts. I was thinking maybe the diafram but not everything else. I haven't got as far as bleeding reading tips. Panicking a little to just get stuff ordered before even more lockdowns Re: Rear Brake refurb - fazersharp - 30-03-20 (30-03-20, 12:28 PM)Gnasher link Wrote: [quote author=fazersharp link=topic=26027.msg311428#msg311428 date=1585566050] As stated above "Push them both out with a single pad between them, get them a equal as possible" [/quote] :thumbup :thumbup Re: Rear Brake refurb - fazersharp - 31-03-20 Ok looking at buying a pair of piston pliers. Any recommendations or advice ones to avoid ect. Trying not to spend too much but I know if I did not have any and I was struggling :'( I would pay anything :lol Re: Rear Brake refurb - Dynspud - 31-03-20 Hey Sharpie. I bought these last year and they work just fine: https://www.ebay.co.uk/itm/Draper-Expert-240mm-Motorcycle-Brake-Piston-Pliers-30838/141965433314?hash=item210dcc99e2:g:Nr8AAOSwYlRZJG7q |
