R1 forks - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: R1 forks (/showthread.php?tid=81544) |
R1 forks - vivfazer - 27-03-20 Hi, I've got some r1 forks to put o my GEN 1 Fazer 1000 They are off 4xv model. Do I need to change the springs as I read the R1 springs are too soft for the fazer . What are the best springs to use. Cheers Re: R1 forks - kebab19 - 27-03-20 It may work 'ok', but if you've gone that far to improve the front-end, you may as well spend a little more to do it right.Your perfect spring rate depends on your weight+ the bike's weight. Plenty of online charts out there to assist you: this bike with a full tank is about 235kg / 517lbs. Just add your own weight and you'll be able to work the revised spring rate out.Or post details and someone will advise... Re: R1 forks - vivfazer - 27-03-20 Many thanks. The combined weight, the bike and my weight approx 747lbs I will see if I can find an online chart. Cheers. Re: R1 forks - vivfazer - 27-03-20 I've check on an online chart. standard road 0.95kgmm Aggressive road 1.0kgmm Does this sound ok. Cheers. Re: R1 forks - unfazed - 28-03-20 Check out the Racetech site https://www.racetech.com/ Re: R1 forks - kebab19 - 28-03-20 1.0 springs sound like they would suit better if you're a fast road rider, carry a pillion or carry a lot of luggage around. 0.95 springs would offer you a comfier ride but might give excess 'dive' on the brakes & front-end going very light under acceleration. You could maybe dial some of that out with the rebound / compression damping. Do the forks have standard internals? Re: R1 forks - vivfazer - 06-04-20 They are standard as far as i know, but I haven't stripped them yet. |
