Valve stem seals - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Valve stem seals (/showthread.php?tid=81540) |
Valve stem seals - Spykeeboi - 25-03-20 Hi guys ive got the cylinder head back from the engineers and while its off i want to completely strip it and clean up valves ect. Ive started removing the valves and ideally replace all the valve stem seals. How i remove these?? do they just push back out from the cylinder side?? do they even come out at all?? I would greatly appreciate any feedback/advise...Thanks Gaz Re: Valve stem seals - bandit - 25-03-20 Should just pull off & push new ones on, I would very lightly apply clean engine oil to valve stem & inside oil stem seal to ease fitting of the valve. Re: Valve stem seals - unfazed - 25-03-20 Pull them off with a pliars , push on the new ones by hand, and as Bandit says, apply some engine oil to the seal inner and the top of the valve guide. Prior to pushing in the valve ensure the area of the valve where the collet locates is perfectly smooth and also the top of the stem. They can, but not always have burrs on them from use. Re: Valve stem seals - Spykeeboi - 25-03-20 Thanks lads much appreciated Re: Valve stem seals - Spykeeboi - 26-03-20 Hi guys...right ive stripped it out as much as i can but im still unsure of what to pull out with pliers. I have some pics but not sure how to resize and upload them. Im not normally this careful but ive just payed to have the plug machined... Thanks Gaz Re: Valve stem seals - red98 - 26-03-20 pictures would be a great help here,if you have removed the valve,collets and spring the seal will be next in line,simple push fit on/off , your not confusing seals with guides are you.....have a go at resizing the piccies and we can get you sorted :thumbup Re: Valve stem seals - Spykeeboi - 26-03-20 (26-03-20, 07:43 AM)red98 link Wrote: pictures would be a great help here,if you have removed the valve,collets and spring the seal will be next in line,simple push fit on/off , your not confusing seals with guides are you.....have a go at resizing the piccies and we can get you sorted :thumbup Hi there im trying to do just that but im not too brill on computers.. could email you the image at all if cant upload it please?? Thanks Gaz Re: Valve stem seals - Spykeeboi - 26-03-20 Ok whilst looking at how to resize the image i was looking at the original image that is quite big being a camara phone and i can see the line where the seal sits on the stem...I presume i just pull the top up with as you said pliers....thanks for your help lads. Gaz Re: Valve stem seals - Spykeeboi - 28-03-20 Hi guys.... ive removed all the seals... Now apart from yamaha where is the best place to get these seals wemoto? ebay?. Thanks Gaz Re: Valve stem seals - red98 - 28-03-20 wemoto are still trading, use them a lot without any problems,the way things are at the moment i would be surprised if you get them before we have beaten the virus... wemoto....£2.68 each, part number AA4423, same part for exhaust and inlet valves Re: Valve stem seals - Spykeeboi - 28-03-20 (28-03-20, 01:32 PM)red98 link Wrote: wemoto are still trading, use them a lot without any problems,the way things are at the moment i would be surprised if you get them before we have beaten the virus... Thanks Red98, Thats great and as i said im in no rush as im really going to clean up intake and exhaust ports. Re: Valve stem seals - Spykeeboi - 30-03-20 (25-03-20, 10:49 AM)unfazed link Wrote: Pull them off with a pliars , push on the new ones by hand, and as Bandit says, apply some engine oil to the seal inner and the top of the valve guide. Prior to pushing in the valve ensure the area of the valve where the collet locates is perfectly smooth and also the top of the stem. They can, but not always have burrs on them from use. Ok so done a little bit of cleaning but while sealing the stems with blu-tac ( to stop crap going down them) I noticed on the very top (cam side) of the stem the exhaust side they are a bit sharp as you say may have burrs on. Intake are smooth...How do i smooth these out??. Also rather than attack it with dremal my train of thought is hit all the crappy carboned up bits with wheel acid (wonder wheels) unless the are rubber seals inside the valve stems this shouldnt be a problem should it. Thanks Gaz |
