Speedo Cable shorting - revised! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Speedo Cable shorting - revised! (/showthread.php?tid=81537) |
Speedo Cable shorting - revised! - pezos - 22-03-20 [color=rgb(0, 0, 0)]Hello,[/color] [color=rgb(0, 0, 0)]So looks like my speedo cable has been routed incorrectly and I found it being sliced in half by one of the front discs. Does anyone know it the cable is its own part that I can replace or does it belong to the (expensive) sensor assembly?[/color] [color=rgb(0, 0, 0)]2002 FZS600[/color] [color=rgb(0, 0, 0)]Many thanks....[/color] Re: Speedo Cable shorting - revised! - unfazed - 23-03-20 Sensor is all one piece including the cable. Should be a few on ebay Re: Speedo Cable shorting - revised! - vinnyb - 23-03-20 Can you not cut and splice it at the break? Re: Speedo Cable shorting - revised! - Disorderlypunk - 23-03-20 if its half way up your in luck- time to get out the soldering iron and some heat shrink Re: Speedo Cable shorting - revised! - Jules-C - 24-03-20 Been meaning to replace my temporary insulating tape repair with a permanent heat shrink solution but the tape lasted about 10 years now Re: Speedo Cable shorting - revised! - pezos - 26-03-20 Hi all Sorry for the delay... been struggling to log in (goggle chrome - using bing now)! Thanks for the replies, does anyone happen to know how many wires are inside the speedo cable if I do need to solder them? Ideally an aftermarket replacement if anyone know where I might find one? Thanks again, much appreciated. Re: Speedo Cable shorting - revised! - Disorderlypunk - 26-03-20 i i remember correctly there are three Re: Speedo Cable shorting - revised! - pezos - 27-03-20 thanks a lot disorderly punk |
