Big Bore / High comp pistons R1?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Big Bore / High comp pistons R1?? (/showthread.php?tid=81505) |
Big Bore / High comp pistons R1?? - killerwhaleTRX - 05-03-20 Hey you knowitalls ![]() As i understand the gen2 is just about the same enjun as R1 2006? With different timing and cams. That would mean same pistons and conn rods?? Just looking what is offered if it is so... Have you been looking on increasing comp or going big bore? Lemme know! Regards Mattias Re: Big Bore / High comp pistons R1?? - unfazed - 05-03-20 Cylinder head, cylinder, pistons and rings are the same, different head gasket and crankshaft Re: Big Bore / High comp pistons R1?? - killerwhaleTRX - 22-05-20 (05-03-20, 07:24 PM)unfazed link Wrote: Cylinder head, cylinder, pistons and rings are the same, different head gasket and crankshaft Conrods should be same also? Same stroke on it.... |
