WANTED ! Fork emulator and springs for FZS600 2002 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: WANTED ! Fork emulator and springs for FZS600 2002 (/showthread.php?tid=81443) |
WANTED ! Fork emulator and springs for FZS600 2002 - Roger65 - 02-02-20 Hi, wanted is the parts for fork upgrades with Emulator and springs that everyone likes. I looking for Linear springs and the Deprix/racetech/YSS simular emulator. It's a 2002 Fzs 600 and I weight 95 kg (info for springs :rollin [size=78%])[/size] Live in Sweden... but will pay for shipping cost of course. If you dont have the kit but do know where to get please send a link ! Cheers Roger Re: WANTED ! Fork emulator and springs for FZS600 2002 - kebab19 - 02-02-20 YSS Emulators https://www.wemoto.com/bikes/yamaha/fzs_600_fazer_sp/02-03/picture/fork_valves Linear springs harder to get but some people have used SV650 springs and changed the length of the internal steel spacers to compensate: https://pdq1.com/product/racetech-front-fork-springs-347x340mm-85kg-frsp-s3534085 Re: WANTED ! Fork emulator and springs for FZS600 2002 - Roger65 - 03-02-20 Hi Kebab19, its your fault I'm doing this modification, your fantastic threads about the fork and rear suspension mods! I saw that you had used VFR800 springs, are they linear and how are they compared to the Racetech you recommend? What year of VFr800 would fit, and do you know any other springs that also could fit from other bikes? About the rear mod with R& shock, is the linkage nesesary to get it to work or only the shock with changed springs ? [size=78%]Would this emulator work:[/size] [/size][size=78%]https://www.ebay.com/itm/41mm-Fork-Damper-Valves-TC-88-Softail-Touring-Dyna-FXST-FLST-FXDWG-FLT-2000-UP-/172661938134[/size] Cheers Roger Re: WANTED ! Fork emulator and springs for FZS600 2002 - kebab19 - 04-02-20 My fault :lol love it!Unfortunately virtually all standard factory front fork springs are dual-rate to suit a wider range of people. Aftermarket linear springs are easier to work with adjustment-wise once you're tinkering around with the setup. You need to source springs from other bikes with 41mm diameter forks and preferably of a similar length to the Fazer's fork springs. The information is out there online. As I said, SV650 linears can do the job and are popular due to the bikes being raced (if you can't find anyone who sells genuine Fazer linear springs). R6 shock - the linkage dogbones have to be changed for shorter versions, as the R6 shock is shorter than the standard Fazer rear shock. Change them or else the rear end will be sitting very low (125-130mm centre to centre holes). I found the standard R6 spring bottomed out on the roads, so changing the spring is almost essential, unless you're very light. That emulator you've listed on ebay looks exactly like the old Debrix emulators I used, so would almost certainly be what you're looking for beware of US import tax, tho... :\ Those emulators also pop up for sale occasionally on SV650 owner forums...Hope you find all your parts! |
