2002 Fazer End Can - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: 2002 Fazer End Can (/showthread.php?tid=81307) |
2002 Fazer End Can - Looey - 03-12-19 Hi all, Just purchased a 2002 (facelift) model that I believe they only made 2002/2003 ?. Want to put an after-market can on, can anyone tell me what year end cans fit. Will all models 98-03 or just the 02/03 models. I can see that the centre stand rubber rests on a bracket on the OEM silencer link pipe, so hopefully the aftermarket ones do too ?. Cheers Re: 2002 Fazer End Can - darrsi - 03-12-19 All the same, 98-03. Re: 2002 Fazer End Can - bandit - 03-12-19 I can see that the centre stand rubber rests on a bracket on the OEM silencer link pipe, so hopefully the aftermarket ones do too ?. Yes aftermarket link pipes come with bracket/bump stop. Buy a end can with a removable baffle then you can take it out if you want or leave it in. Re: 2002 Fazer End Can - Looey - 04-12-19 Thanks guys
Re: 2002 Fazer End Can - the swan fiend - 17-12-19 I've got an MTC can on mine with the baffle removed. Its been on about 10 years and still looks as good as the day I fitted it. Gives a better sound, weighs less, but I had to tweek the carbs as it ran very lumpy at low revs. |
