Fazer rear caliper - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fazer rear caliper (/showthread.php?tid=81229) |
Fazer rear caliper - MC900 - 26-10-19 Hi guys, Just had a Fazer thou rear caliper fitted to my fzs600. The rear brake is very sensitive, only have to rest my foot on the pedal to get sharp braking, is that normal? Also the rear brake light doesn't activate until the brake lever is pressed quite hard, if I press it that hard though it will probably lock the rear. Is there anyway of fixing this? Just had this caliper fitted at a garage. Cheers. Re: Fazer rear caliper - bandit - 26-10-19 Click on downloads & select manuals on the left, check pedal height adjustment & black plastic brake light switch with wires going to it at rear of pedal can be rotated up or down to alter when lights come on. [img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img] Re: Fazer rear caliper - darrsi - 26-10-19 Dunno what condition your bike is in, but use a can of brake cleaner, WD40, etc, to clean inside the pivot of the foot lever, as over time it can get clogged up with dirt and affect the braking quality. Especially if you're altering sensitivity. Re: Fazer rear caliper - Jeansoy - 03-12-19 You are my helper I want to thank you so much for imparting to me. |
