Front caliper upgrade - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front caliper upgrade (/showthread.php?tid=81184) |
Front caliper upgrade - the cueball - 04-10-19 A lot of chat (rightly so) about upgrading the rear caliper of the 600 to the blue dot... What about the fronts? Is it an easy upgrade from the blue dot to the FZS1000 gold dots?? Just bolt off, bolt on?? I don't have any issues with my blue dots, I think they are fine.. but have the chance of golds at a good price... and well...always good to buy stuff... :rollin :rollin :thumbup Re: Front caliper upgrade - unfazed - 04-10-19 You mean like this Re: Front caliper upgrade - the cueball - 04-10-19 Yes... but with the box eye... Looks good though..
Re: Front caliper upgrade - unfazed - 04-10-19 Brakes are exactly the same on all the FZS600 from 1998 to 2003 Re: Front caliper upgrade - the cueball - 04-10-19 (04-10-19, 11:33 AM)unfazed link Wrote: Brakes are exactly the same on all the FZS600 from 1998 to 2003 good stuff... gold goldie stuff for me then! :rollin Re: Front caliper upgrade - Jamieg285 - 04-10-19 Apart from the colour, what's the difference between the std Blues and these Gold ones? Re: Front caliper upgrade - darrsi - 04-10-19 Surely there can’t be much of an improvement? If the front calipers are properly maintained and functioning correctly then they are more than enough for these bikes, in fact if you’re not careful and grab a handful of brake you may well experience what flying is like. :lol Re: Front caliper upgrade - BBROWN1664 - 04-10-19 (04-10-19, 12:59 PM)Jamieg285 link Wrote: Apart from the colour, what's the difference between the std Blues and these Gold ones? I seem to recall this has been discussed before and the only difference was the colour. You cannot really upgrade from the blue spots unless you want to spend mega money and even then, the benefits would be smashed out the way by the front forks. Best upgrades on the FZS are braided hoses and thicker fork oil along with some new springs. Re: Front caliper upgrade - kebab19 - 04-10-19 From memory, the silver-spot and gold-spot calipers have aluminium pistons in them: as such they're a softer metal and so the pistons are slightly thicker (internally) to compensate. I believe the thinking behind them is less likely to rust or seize up. They might also be fractionally lighter, but offer no improvement in braking quality, nor significant proof of improved heat dissipation. Re: Front caliper upgrade - unfazed - 04-10-19 :agree They are less prone to corrosion and pitting compared to the standard Blue Spot. My only reason for changing them was only because I thought they look better, it was afterwards I discovered there was a difference in the pistons. Re: Front caliper upgrade - Gnasher - 19-01-20 (04-10-19, 05:05 PM)BBROWN1664 link Wrote: [quote author=Jamieg285 link=topic=25663.msg303159#msg303159 date=1570190377] I seem to recall this has been discussed before and the only difference was the colour. You cannot really upgrade from the blue spots unless you want to spend mega money and even then, the benefits would be smashed out the way by the front forks. Best upgrades on the FZS are braided hoses and thicker fork oil along with some new springs.[/quote] :agree Yep it sure has and you can't not really. These calipers were and still this side of a track the best out there. Any money spent trying to up grade for performance would be a waste, if you want looks well fill you're boots but it's going to cost you for little or no gain. |
