Fzs1000 rear Caliper - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Fzs1000 rear Caliper (/showthread.php?tid=81176) |
Fzs1000 rear Caliper - Riggerlee88 - 30-09-19 Managed to get my hands on a fzs1000 rear Caliper for £40!!! Delighted with that outcome. it Has arrived today doesn’t look in too bad of shape but I want to strip them down and change all the seals. My question is how do I remove the pistons on these do I need to buy a blue spot tool also is that the same for the front as I will work on them too? Just refurbed my rear 600 Caliper if anyone is interested just needs new seals and bleed nipples. Re: Fzs1000 rear Caliper - red98 - 01-10-19 hi riggerlee.........£40 for a thou rear caliper was a bargain , well done :thumbup .......no special tool needed for removing the pistons just pop them out with the brake lever.......i`am interested in you old caliper if its for sale , been looking for a thou one but not as lucky as you :\ Re: Fzs1000 rear Caliper - Riggerlee88 - 02-10-19 Hi Red98, thank you for the information mate worked a treat use the air gun to pop the pistons out no issues at all just need to change the seals and will go about fitting the new set on the bike, I was really lucky to find it by setting an alert on Ebay just popped up I jumped straight onto it!!! I have attached some pics of the 600 caliper for you to have a look at if you are interested as I say just missing the seals and pads as I was to replace them. Re: Fzs1000 rear Caliper - Carpy - 02-10-19 My bad Can't delete my reply !! Re: Fzs1000 rear Caliper - red98 - 03-10-19 hi riggerlee ,glad you got the thou pistons out ok and thanks for posting the pics , 600 caliper looks very good , let me know how much and i think we can do a deal :thumbup ... Re: Fzs1000 rear Caliper - Riggerlee88 - 04-10-19 Hi Red98, I have sent you a PM ref the rear 600 caliper let me know your thoughts cheers Re: Fzs1000 rear Caliper - red98 - 04-10-19 hi riggerlee, no message this end, you want to try again..... Re: Fzs1000 rear Caliper - Riggerlee88 - 06-10-19 Hi Red, Apologies not sure why it’s not come through will try again now
Re: Fzs1000 rear Caliper - red98 - 06-10-19 hi Riggerlee , thanks for trying again, i just replied.... Re: Fzs1000 rear Caliper - Tefer - 09-04-20 Did you get your FZS1000 caliper fitted, any steps on what to do, i have one to fit but i believe there is adjustment needed to the bracket and spacers to be fitted. Re: Fzs1000 rear Caliper - Flak - 12-04-20 You'll have to file a little bit off the hanger - not a big deal. I fitted a couple of washers to centralise the hanger with the disc, it will be obvious when you come to fit it. Altogether a definite upgrade. Re: Fzs1000 rear Caliper - Tefer - 21-04-20 (12-04-20, 06:11 PM)Flak link Wrote: You'll have to file a little bit off the hanger - not a big deal. do the washers go between the bracket and the caliper then? Do you know size needed and how many? Re: Fzs1000 rear Caliper - Flak - 22-04-20 (21-04-20, 03:23 PM)Tefer link Wrote: do the washers go between the bracket and the caliper then? Do you know size needed and how many?I'll take a pic later for you. Re: Fzs1000 rear Caliper - Flak - 23-04-20 Please excuse the grubbiness of the bike, it's my winter hack. 2 ordinary 10mm flat washers, just try to get the caliper as central with the disc as you can. Re: Fzs1000 rear Caliper - Tefer - 30-04-20 (23-04-20, 09:53 AM)Flak link Wrote: Please excuse the grubbiness of the bike, it's my winter hack. Many thanks mate. |
