Rear LED light bar issue - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Rear LED light bar issue (/showthread.php?tid=81094) |
Rear LED light bar issue - Riggerlee88 - 24-08-19 Hoping for someone’s help. I have an Integrated LED light bar with indicators. The light works fine when the bike is on tick over what seems to be the issue is after a ride the light bar seems to malfunction (flashes non stop) until I turn off the bike and restart. On my Koso dash I have a volt meter which reads when riding 14.2 V is this too high? Also if I take the rpm up to around 10k+ the Koso Rev gauge also plays up until I restart the bike. So my question is should the bike when riding generate 14.2v and or is my regulator rectifier faulty. To confirm the bike is full LED conversion and a LED indicator relay installed to eradicate the fast pulse. Any help would be greatly appreciated. Re: Rear LED light bar issue - limax2 - 26-08-19 14.2 volts on you dash mounted gauge sounds fine. I think mine shows about 14.5 volts when I've measured it at the battery with a few revs on the engine. The Yamaha manual quotes a no load regulated voltage of 14.1 to 14.9. I have zero knowledge on LED stuff. Re: Rear LED light bar issue - Riggerlee88 - 26-08-19 Thank you for your response it’s much appreciated glad to know that’s the acceptable range which helps me eradicate the regulator rectifier ?? Re: Rear LED light bar issue - BBROWN1664 - 26-08-19 let us know how you get on with the MOT using the lightbar as they are clamping down on the distance between indicators now. Re: Rear LED light bar issue - Riggerlee88 - 27-08-19 I managed to get it through in April without them mentioning anything, the current light bar I am using converts half of the bar into the indicator as oppose to just the end portions (much safer) but technically I have zero separation between left and right I suppose it is pot luck |
