Clutch pull rod / lever alignment - help please - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Clutch pull rod / lever alignment - help please (/showthread.php?tid=81070) |
Clutch pull rod / lever alignment - help please - Old-Git - 15-08-19 As per the title. Clutch plate replacement is dead easy, but sever hours later I'm struggling to get the pull rod and lever aligned properly. Any hints or tips out there? Thanks Re: Clutch pull rod / lever alignment - help please - unfazed - 15-08-19 Did you align the punch mark on the pressure plate with the the clutch boss before installing the springs and tightening the bolts. Re: Clutch pull rod / lever alignment - help please - Old-Git - 15-08-19 (15-08-19, 05:19 PM)unfazed link Wrote: Did you align the punch mark on the pressure plate with the the clutch boss before installing the springs and tightening the bolts. Ah. No. :o Can you explain a little more please? Thanks Re: Clutch pull rod / lever alignment - help please - unfazed - 15-08-19 This Re: Clutch pull rod / lever alignment - help please - Old-Git - 15-08-19 Many thanks for this, will have another look in the morning. Cheers Re: Clutch pull rod / lever alignment - help please - Old-Git - 16-08-19 All sorted now thanks. I will not mention the error which occurred when re-assembling the clutch :rolleyes Re: Clutch pull rod / lever alignment - help please - unfazed - 16-08-19 Ah! go on, tell us. :eek
Re: Clutch pull rod / lever alignment - help please - Old-Git - 17-08-19 mumble mumble didn't know about the smaller cork plate going in first puts hands in pockets and shakes head looks sheepish. Changes subject - I'm doing a track day at Bedford on Monday! Re: Clutch pull rod / lever alignment - help please - unfazed - 17-08-19 :lol Take heart, You are not the first person to do that. Enjoy the track day and don't forget to post a few pics
Re: Clutch pull rod / lever alignment - help please - Old-Git - 20-08-19 Cracking day on the track, while it lasted - rained off after lunch. The old girl went really well. I saw over 140mph on the back straight. Suspension (wilburs fork springs, r6 shock) working really well, only limitation is ground clearance and I can't do anything about that until I can get more bend in my knee and go back to standard footpegs. Still got a touch of clutch slip tho, might have to replace the metal plates over the winter, https://photos.google.com/photo/AF1QipPoOItsiAGUqHqEBDKiydYxeAeNSOd-HHw3lCMw and https://photos.google.com/photo/AF1QipPpGKdmSItovtR1b-LbpsOcv72liRWeBqYDfbVH when I insert these as a pic Re: Clutch pull rod / lever alignment - help please - agricola - 20-08-19 Links aren't working Re: Clutch pull rod / lever alignment - help please - Old-Git - 21-08-19 Track Day Pics! I have noi idea why 2 of then aren't upright. Re: Clutch pull rod / lever alignment - help please - robbo - 21-08-19 Nice to know there's another high-level afficianado about. Although don't have mine fitted at present as need to have pannier frames fitted. What make is that?. Re: Clutch pull rod / lever alignment - help please - unfazed - 21-08-19 A good day out was had I would presume. Weather looked like it was good
Re: Clutch pull rod / lever alignment - help please - Old-Git - 21-08-19 Exhaust is an IXIL. You can hear it here https://youtu.be/bQ3Vctr-r9k and did I mention how good the brakes are
Re: Clutch pull rod / lever alignment - help please - agricola - 21-08-19 Looks like a good day out. I reckon Id get confused at Bedford, too many white markings across the track. |
