Deklevic headers and no exup - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Deklevic headers and no exup (/showthread.php?tid=81024) |
Deklevic headers and no exup - goldfazer - 30-07-19 OK, the saga of the exup continues. I won't bore you with the details, but the selling dealer is saying that as it has a Deklevic an already, it'll run fine with Delklevic headers with no exup. My workshop says that's crap. What say you lot? Re: Deklevic headers and no exup - goldfazer - 30-07-19 FZS1000, 2005 Re: Deklevic headers and no exup - Dudeofrude - 30-07-19 It wont run 'fine' without the exup unless its tuned to do so. My understanding with the gen 1 is that the exup helps with low down power by creating back pressure at low rpms. With it removed and no change to the fueling I believe it would become rough and a bit gutless down low. I'm sure it would be rideable but I doubt it would be an improvement Re: Deklevic headers and no exup - goldfazer - 30-07-19 Cheers. I'm heading for the 'pay for it myself and take 'em to the small claims court' route I think. Re: Deklevic headers and no exup - Falcon 269 - 31-07-19 It will run OK with the Delkevic headers but not as it should and no amount of tuning will fix that. The only aftermarket headers designed and proven to retain the scavenging characteristics of the OE EXUP system were made by Muzzy in the USA. These are no longer in production. All the others available, including Akrapovic, soften the power delivery below 4k rpm and in the worst cases, create a flatspot in that region which can't be tuned out via carb mods or anything else. Technically, I think you'd have a hard time getting a satisfactory outcome through legal action because the bike does run 'OK' with the headers fitted when you bought it. Good luck, though. Re: Deklevic headers and no exup - WayneUK - 31-07-19 i had same problem with my 2003 with a beowulf fitted, the guys at the dealers workshop said it doesnt need it with having that can on and said they can put a eliminator to stop the tach error,but didnt make any difference, but when the main mechanic came back from being off ill, he rang me and said it needs the exup sorting its not right without it,he had it for a week, he put new cables and valve in, as he said the one in was completely siezed, and now its been done what a difference it makes,I noticed the difference in sound soon as he started it up and now runs much smoother at low and high speed. Re: Deklevic headers and no exup - goldfazer - 31-07-19 (31-07-19, 06:11 AM)Falcon 269 link Wrote: Technically, I think you'd have a hard time getting a satisfactory outcome through legal action because the bike does run 'OK' with the headers fitted when you bought it. Good luck, though. I'm not sure about that - it has a fault and as I asked them if the exup was OK when I bought it and was told yes, I think I have a decent case. The Mrs is on the case anyway - she's a terrier..... Re: Deklevic headers and no exup - Falcon 269 - 31-07-19 Fair enough ... if they didn't tell you the EXUP was effectively missing and the reason why, I agree that they withheld information pertinent to the sale. Have at 'em!
Re: Deklevic headers and no exup - b1k3rdude - 31-07-19 Quote:Technically, I think you'd have a hard time getting a satisfactory outcome through legal action because the bike does run 'OK' with the headers fitted when you bought it. Good luck, though.Er no, what this cunt of a dealer has done is commit fraud! and yet still persist with the fucking outright audacity. (31-07-19, 05:04 PM)Falcon 269 link Wrote: if they didn't tell you the EXUP was effectively missing and the reason why, I agree that they withheld information pertinent to the sale.Its far worse than that Mike and what they have done carries some very serious penalties for the dealer concerned. The Consumer Rights Act 2015 is very clear -
Re: Deklevic headers and no exup - goldfazer - 01-08-19 Just to clarify, it has the std headers and a stuck exup valve (well, had as it's been removed ).
Re: Deklevic headers and no exup - goldfazer - 01-08-19 I'll name the dealer when it's sorted. But it's a Honda dealer in Manchester Re: Deklevic headers and no exup - VNA - 01-08-19 Just in case anybody is looking for headers....... I think holeshot headers are still available. Ceramic coated steel rather than stainless though. But properly researched rather than thrown together. But wouldn't think they would be much use with standard carbs.Probably OK with Ivans kit fitted?But as Mike says will still be a touch softer than EXUP below 4000rpm. Good luck with getting a result here. Re: Deklevic headers and no exup - goldfazer - 03-08-19 Update, got a used exup from ebay for £154. The dealer are basically telling me to get stuffed so I'll be filling in the small claims form shortly
Re: Deklevic headers and no exup - goldfazer - 07-08-19 Finally got her back. £154 for used exup (ebay) and £175 labour. Could have been much worse! Will now fire up the small claims court Re: Deklevic headers and no exup - b1k3rdude - 07-08-19 (07-08-19, 06:39 PM)goldfazer link Wrote: £175 labour.Er wtf were your local shop doing that it took 3-4 hours to swap an exup valve..? Re: Deklevic headers and no exup - ogri48 - 07-08-19 glad you got it sorted dude.
Re: Deklevic headers and no exup - goldfazer - 08-08-19 (07-08-19, 09:08 PM)b1k3rdude link Wrote: [quote author=goldfazer link=topic=25503.msg301377#msg301377 date=1565199581]£175 labour.Er wtf were your local shop doing that it took 3-4 hours to swap an exup valve..? [/quote] 2 hrs to remove (inc. headers), drill and thread the stuck bolts. 1 hr to replace! Re: Deklevic headers and no exup - goldfazer - 08-08-19 Actually, a bit less than 3 hrs. It was £175 inc vat and £55/hr + vat Re: Deklevic headers and no exup - b1k3rdude - 09-08-19 (08-08-19, 09:43 AM)goldfazer link Wrote: drill and thread the stuck bolts.Ah yes, that old chestnut. I look forward to hearing how the dealer that sold bike pays for all this work. |
