FZS1000 7k on tacho at startup - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: FZS1000 7k on tacho at startup (/showthread.php?tid=80980) |
FZS1000 7k on tacho at startup - goldfazer - 13-07-19 Just got me a Gen 1 thou and the tacho jumps to 7k then back to 0. Is this OK or an Exup fault? Re: FZS1000 7k on tacho at startup - old son - 13-07-19 Scup fault. Probably needs a lube and adjustment. Re: FZS1000 7k on tacho at startup - goldfazer - 13-07-19 Doesn't show a fault when running though, just on ign on. Re: FZS1000 7k on tacho at startup - BMCfaz - 13-07-19 I regularly service and lube the EXUP on mine, but it still does the same as yours on startup. It works fine once the engine is running, so I've given up worrying about it. Re: FZS1000 7k on tacho at startup - b1k3rdude - 13-07-19 (13-07-19, 07:58 PM)goldfazer link Wrote: Doesn't show a fault when running though, just on ign on.Correct, think of this as the bike giving you your last warning. Essentially whats happening is the exup valve is binding to the point its preventing the exup servo from moving the valve. And as a lot of fellow thou owners will tell you -
Re: FZS1000 7k on tacho at startup - goldfazer - 14-07-19 Great, thanks. I'll get some pen. oil on them and plan to get my local shop to do it and get the dealer I bought it from to pay as I asked them to check it was OK, it was meant to have been serviced and still got delivered with the fault... Re: FZS1000 7k on tacho at startup - b1k3rdude - 16-07-19 regarding those small bolts, I was refering to the 3x allen bolts that hole the vale end plate on, not the 3x small m8 bolts that hold the pully cover on - Here is a VERY nice guide (Photos look like they are from our own Falcon) - https://www.tapatalk.com/groups/fazer1000/exup-valve-maintenance-t1524.html These bolts don't tend to seize - ![]() These ones DO...!!! - replace these with stainless or better Titainium ![]() Re: FZS1000 7k on tacho at startup - WayneUK - 19-07-19 Hi all, I've just recently bought a fazer 1000 2003, and it shows the EX UP fault , i took it back to the dealers and they have fitted a eliminator,but its still showing the fault?the valve has seized open but not connected by the servo, the fault doesn't seem to happen if im going over 50 mph, just seems to be below that? but some times seems to be ok on that, and always shows when the ignition is switched on, it also has a beowolf exhaust any advise on why it might still show up with a eliminator connected? Re: FZS1000 7k on tacho at startup - tex - 19-07-19 If you brought it from the dealers I would tell them to fix the exup properly, putting a eliminator on doesn't fix the problem, the bike won't run correctly with the exup open at low revs Re: FZS1000 7k on tacho at startup - Trebus - 19-07-19 +1. I’d insist it was fixed correctly. Or knock £200 off so you can sort it yourself. Re: FZS1000 7k on tacho at startup - coffee - 19-07-19 (19-07-19, 11:30 AM)tex link Wrote: If you brought it from the dealers I would tell them to fix the exup properly, putting a eliminator on doesn't fix the problem, the bike won't run correctly with the exup open at low revs Does this only apply to Gen 1only,because when I bought my Gen 2 the exup had been disconnected and the cables were underneath the seat,I have a Scorpion pipe and it runs through the rev range ok,with a bit of a snatchy throttle at low revs and popping on the overrun,apart from that it seems ok.I would like to lose that snatchy throttle but figured it was because it's fuel injection and not carbs which always seem nicer on low speed pick up,does anyone think a Power commander would help? Re: FZS1000 7k on tacho at startup - BBROWN1664 - 19-07-19 (19-07-19, 09:27 PM)coffee link Wrote: [quote author=tex link=topic=25459.msg300721#msg300721 date=1563532236]Does this only apply to Gen 1only,because when I bought my Gen 2 the exup had been disconnected and the cables were underneath the seat,I have a Scorpion pipe and it runs through the rev range ok,with a bit of a snatchy throttle at low revs and popping on the overrun,apart from that it seems ok.I would like to lose that snatchy throttle but figured it was because it's fuel injection and not carbs which always seem nicer on low speed pick up,does anyone think a Power commander would help? [/quote] Yes it applies. I think a PC will help, but if you have the original downpipes and the valve fitted, reconnecting the exup will be better than the PC alone. Re: FZS1000 7k on tacho at startup - PieEater - 20-07-19 (19-07-19, 09:27 PM)coffee link Wrote: [quote author=tex link=topic=25459.msg300721#msg300721 date=1563532236]Does this only apply to Gen 1only,because when I bought my Gen 2 the exup had been disconnected and the cables were underneath the seat,I have a Scorpion pipe and it runs through the rev range ok,with a bit of a snatchy throttle at low revs and popping on the overrun,apart from that it seems ok.I would like to lose that snatchy throttle but figured it was because it's fuel injection and not carbs which always seem nicer on low speed pick up,does anyone think a Power commander would help? [/quote] The valve on the Gen2 is for noise / emissions purposes only and unlike the Gen1 has no effect on the bikes performance or power delivery. Again unlike the Gen1 the valve on the Gen2 is located in the OEM end can (not in the downpipes) so fitting any aftermarket can such as your Scorpion will necessitate having the cables disconnected and left in a convenient location like under the seat. So no the advice for a Gen1 EXUP valve does not apply to the Gen2. Re: FZS1000 7k on tacho at startup - coffee - 20-07-19 (20-07-19, 09:04 AM)PieEater link Wrote: [quote author=coffee link=topic=25459.msg300737#msg300737 date=1563568051]Does this only apply to Gen 1only,because when I bought my Gen 2 the exup had been disconnected and the cables were underneath the seat,I have a Scorpion pipe and it runs through the rev range ok,with a bit of a snatchy throttle at low revs and popping on the overrun,apart from that it seems ok.I would like to lose that snatchy throttle but figured it was because it's fuel injection and not carbs which always seem nicer on low speed pick up,does anyone think a Power commander would help? [/quote] The valve on the Gen2 is for noise / emissions purposes only and unlike the Gen1 has no effect on the bikes performance or power delivery. Again unlike the Gen1 the valve on the Gen2 is located in the OEM end can (not in the downpipes) so fitting any aftermarket can such as your Scorpion will necessitate having the cables disconnected and left in a convenient location like under the seat. So no the advice for a Gen1 EXUP valve does not apply to the Gen2. [/quote] Thanks for that,top man. :thumbup Re: FZS1000 7k on tacho at startup - WayneUK - 21-07-19 thanks for the advise I'm taking it back in today Re: FZS1000 7k on tacho at startup - b1k3rdude - 22-07-19 I see 2 people have mentioned 'FC eliminator' and a 'PowerCommander', er its a Gen1 bike guys - neither of those products would apply to this bike due to it NOT being fuel injected, its a carbureted model :pokefun Re: FZS1000 7k on tacho at startup - coffee - 23-07-19 (22-07-19, 07:38 PM)b1k3rdude link Wrote: I see 2 people have mentioned 'FC eliminator' and a 'PowerCommander', er its a Gen1 bike guys - neither of those products would apply to this bike due to it NOT being fuel injected, its a carbureted model :pokefun Until I read this I never realised a Power Commander was only for fuel injected motors. :o Re: FZS1000 7k on tacho at startup - tex - 23-07-19 (22-07-19, 07:38 PM)b1k3rdude link Wrote: I see 2 people have mentioned 'FC eliminator' and a 'PowerCommander', er its a Gen1 bike guys - neither of those products would apply to this bike due to it NOT being fuel injected, its a carbureted model :pokefun Haven't seen fc eliminator mentioned, exup eliminator was mentioned this is for a gen 1 they put it on Wayne bike to stop the 7k fault, as I said it won't cure the problem of a stuck open exup! Coffee has a fuel injected bike and was asking if it was relivent for his bike and would a power commander help with his bike . Hope that sorts it for you ! Re: FZS1000 7k on tacho at startup - WayneUK - 26-07-19 Well. got bike back today after them sorting exup out , new cables and valve, now seems real smooth :thumbup Re: FZS1000 7k on tacho at startup - Trebus - 26-07-19 ???? |
