Will later fzs 2002---2004 engine fit?? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Will later fzs 2002---2004 engine fit?? (/showthread.php?tid=80971) |
Will later fzs 2002---2004 engine fit?? - Dinger1962 - 09-07-19 Wondering if later engine will fit my bike (99 plate) am sure i read on here somewhere that it would maybe need to change couple of plugends any ideas ??am not upto complete stipdown to repair gearbox thanks in advance-- Re: Will later fzs 2002---2004 engine fit?? - BBROWN1664 - 10-07-19 Yes, it will fit but a couple of the connectors may need to be changed/adapted. Cannot recall which ones though. Re: Will later fzs 2002---2004 engine fit?? - unfazed - 10-07-19 Get the Foxeye regulator/rectifier to replace your own and then swap the connector on it and the connector to the stator from you own and everything will be a straight swap. The charging system on the Foxeye was much improved over the Boxeye and theĀ Stator, Rotor and Regulator/rectifier were changed. Re: Will later fzs 2002---2004 engine fit?? - Dinger1962 - 10-07-19 Thanks chaps-- Re: Will later fzs 2002---2004 engine fit?? - Grib - 10-07-19 2004 is a completely different engine to 2002 though.... Re: Will later fzs 2002---2004 engine fit?? - unfazed - 10-07-19 (10-07-19, 08:13 PM)Grib link Wrote: 2004 is a completely different engine to 2002 though....Yes and no as many 02-03 FZS600s outside the UK were registered in 2004 |
