fork top bolts/caps - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: fork top bolts/caps (/showthread.php?tid=80866) |
fork top bolts/caps - daviee - 08-06-19 can any one confirm if the later adjustable fork tops fit the early non adjustable forks ? Re: fork top bolts/caps - bandit - 08-06-19 I'm sure they do but I believe the internals i.e the springs & spacer tubes are different sizes to later ones,so not just a case of changing the caps. Re: fork top bolts/caps - darrsi - 08-06-19 (08-06-19, 09:43 AM)bandit link Wrote: I'm sure they do but I believe the internals i.e the springs & spacer tubes are different sizes to later ones,so not just a case of changing the caps. Correct, plus oil levels are different too. Personally though, when i had the adjusters on my forks (swapped for older ones) i found them to be quite useless, and had them wound right in at the firmest setting. Changing the fork oil to 15w instead of 10w will markedly improve the front end feel without a doubt. Re: fork top bolts/caps - daviee - 08-06-19 cheers guys i have done the oil springs and emulators but the standard ones were already marked so thinking of changing them but few and far between , but i can get these cheep https://www.ebay.co.uk/itm/Black-Billet-Front-Fork-Preload-Adjusters-Fit-Yamaha-FZ-S-600-Fazer-00-03-01-02/322042395469?fits=UKM_Make%3AYamaha%7CUKM_CCM%3A600%7CUKM_Model%3AFZS&hash=item4afb38fb4d:g:ZvkAAOSwySlZ6Vvp#vi-ilComp Re: fork top bolts/caps - cl1ve2004 - 10-06-19 Look great !! Trying to adjust them might be interesting tho'.... Re: fork top bolts/caps - daviee - 10-06-19 why its a normal socket that fits them Re: fork top bolts/caps - cl1ve2004 - 10-06-19 Fair enuff.. Probably be easier than standard ones to adjust then :thumbup |
