Clutch cable! Routing. FZS - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Clutch cable! Routing. FZS (/showthread.php?tid=80863) |
Clutch cable! Routing. FZS - Decoke Dave - 07-06-19 Made a fundamental error! Went to change my clutch cable without pulling a fine piece of string behind it to check the routing. OK with all the clips etc, but under the left side of the tank there seems to be no sympathetic way to route it, there is a rubber cup thing that looks like its meant to go on there? But but after that I am clueless! Can anyone attempt to explain to me exactly what the original routing is. Re: Clutch cable! Routing. FZS - unfazed - 07-06-19 Download the service manual http://foc-u.co.uk/index.php?action=downloads;sa=downfile&id=11 and it and go to page 2-35. From there on it shows the routing of the clutch cable Re: Clutch cable! Routing. FZS - Decoke Dave - 07-06-19 Many thanks, but correct me if I am wrong it seems that from the handlebars and under the left side of the tank the clutch cable follows the same path as the choke cable? P.S. my FZS is a 2004. Re: Clutch cable! Routing. FZS - Flooky - 08-06-19 Did mine the other week, from lever under tank then right by the rubber boot on the cable (gen yam one ) it goes in a clip then across under carbs to clutch arm. your right though the bend to go across looks tight Re: Clutch cable! Routing. FZS - unfazed - 08-06-19 (07-06-19, 11:34 PM)Decoke Dave link Wrote: Many thanks, but correct me if I am wrong it seems that from the handlebars and under the left side of the tank the clutch cable follows the same path as the choke cable? P.S. my FZS is a 2004.Yes a similiar path, but the clutch cable goes into the holder on the left frame tube whereas the choke cable does not. Re: Clutch cable! Routing. FZS - Decoke Dave - 08-06-19 Must agree, that's the way mine seems to have been, only thing is looking at the download manual the clutch cable does not seem to go into the left hand side frame tube large plastic snap clip? (have a look and see what you think). It was the tight bend after this clip back to the outside that was putting me off using it. So i didn't put my one into it, much straighter thus smoother path left out of it! There is genuine cable tie farther up the cables/wiring nearer the head stock that hold it in position anyway. Like to hear any views on the manual drawing. |
