Heavy Throttle & no pull low down - 2005 FZS1000 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Heavy Throttle & no pull low down - 2005 FZS1000 (/showthread.php?tid=80844) |
Heavy Throttle & no pull low down - 2005 FZS1000 - b1k3rdude - 31-05-19 Ok So I haven't been riding the FZS for a long while, first winter and then ULEZ and Jumped on the bike today and found some niggles -
Re: Heavy Throttle & no pull low down - 2005 FZS1000 - ogri48 - 31-05-19 I dont think its anything drastic mate. a sticky cable probably; its suprising the difference that makes. One time I routed the throttle cable slightly wrong after swapping the carbs out and my throttle was stiff, another time it was when I adjusted the cables too tight. as for jumping off the bandito onto the thou...its exactly the same for me when ive been riding the cb1300 then use the fazer..it feels like a 600 low down. The thou is a fantastic bike, but it aint got the grunt of the bigger cubed bikes. you'll get it sorted bud...
Re: Heavy Throttle & no pull low down - 2005 FZS1000 - PieEater - 01-06-19 Ignition advancer would help assuming you don't already have one fitted. Re: Heavy Throttle & no pull low down - 2005 FZS1000 - unfazed - 01-06-19 I always found the 1000 was a bit soft until 3500 revs. A non working EXUP makes it feel worse although some do not think so.First port of call is check the EXUP is set correctly.Synchronise the carburettors set the idle and then set the TPS. If it still feels soft then change the throttle tube to R6 type the models from 2006 onward, Easy cheap fix. I always felt the 1000 had a very lazy throttle compared to other large capacity bikes I have ridden and the R6 tube sorted it, much more enjoyable to ride now Re: Heavy Throttle & no pull low down - 2005 FZS1000 - ogri48 - 01-06-19 gotta admit thats the last mod on my list. I'll havta dig out the thread mate
Re: Heavy Throttle & no pull low down - 2005 FZS1000 - b1k3rdude - 02-06-19 (01-06-19, 09:33 AM)PieEater link Wrote: Ignition advancer would help assuming you don't already have one fitted.I did buy one ages ago and never fitted it so sold it, might go and get another one if it will help the pull below 3k. (01-06-19, 12:59 PM)unfazed link Wrote:
Re: Heavy Throttle & no pull low down - 2005 FZS1000 - b1k3rdude - 04-06-19 On the heavy throttle issue, lubing the cables made no difference and they were already quite free - only the push cable had a worn-in kink so I got a set on slinky cables and a clutch cable from wemoto as it cant hurt. |
