tyre plugs - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: tyre plugs (/showthread.php?tid=80814) |
tyre plugs - celticdog - 23-05-19 Okay so the rear tyre gets a puncture, I only purchased it 3 months ago and it's probably done less than 1500 miles. :'( I've pulled a nail out of the tread and plugged it, clean puncture- easy fix with one of those kits. All's well as it's got me home safely. Now the tyre pressures holding, What's the verdict? Should I get a new tyre asap or do I run it till it's ready for replacing? The bikes for commuting and as such I very rarely exceed 70 mph. Re: tyre plugs - robbo - 24-05-19 Run it until it needs replacing. Did about 2,500 miles on my last rear that I plugged. Got a puncture in my current rear last Saturday which I plugged and will run that until it's due to be changed. Watched a youtube clip about a tyre plugging product called Dynaplug, no glue or enlarging of the hole required. I'm happy with the kit I use, but it certainly was an interesting idea. Re: tyre plugs - Grahamm - 24-05-19 (23-05-19, 11:04 PM)celticdog link Wrote: What's the verdict? Should I get a new tyre asap or do I run it till it's ready for replacing? Go to a friendly local tyre fitter and get them to take it off and have a check inside. If necessary, get them to replace the "sticky string" with a proper mushroom plug or buy a new tyre, because whilst it may look like it's ok from the outside, there could be damage inside the carcass that isn't visible and could fail catastrophically without warning. Spending a few quid to get it checked out is much better than taking a chance. (This is paraphrasing advice from Russ of Russ' Tyres in Portsmouth who has around 30 years of experience and comes highly recommended by a lot of bikers down here :thumbup ) Re: tyre plugs - darrsi - 24-05-19 Another perspective, if you were unlucky enough to keep getting punctures every few days would you keep buying new tyres? No. You would get to the point where you would ride further and further and use up as much of the tyre as you can as it would become a financial nightmare otherwise. If you were doing high speeds on a daily basis then that's most certainly a different prospect, but i've run a tyre down before on a plug with no issues although as you know my bike is mainly a commuter so i wasn't too worried anyway. But as mentioned if the tyre's still in good shape with plenty of mileage left then a mushroom plug would be the way to go for peace of mind. All the better if you can remove the wheel yourself and get it down to a proper fitter who deals regularly with bike tyres then it won't cost as much to get fixed. Re: tyre plugs - robbo - 24-05-19 My puncture outfit is the Pocket Tyre Plugger, which uses mushroom style plugs. Not cheap, but it does work. Re: tyre plugs - Dynspud - 24-05-19 Same for me Robbo. A wicked little kit that works well and comes in a handy zipped pouch to carry around with you too. Re: tyre plugs - dangerousdave - 24-05-19 I'd put some tyre sealant in there as a backup! Re: tyre plugs - Red Ceri - 24-05-19 I'm with Grahamm, off to my local tyre shop to check the tyre for any other damage and put a mushroom plug in it Re: tyre plugs - b1k3rdude - 24-05-19 Got a screw in my rear yesterdaying evening, recovery guy one of those rivet type plugs in - solid as a rock upto 3 figures and now loss of pressure. Re: tyre plugs - celticdog - 25-05-19 Cheers to all for the tips and ideas, I've a 500 mile round trip to do next week so will defo get it checked over and hopefully get it plugged with a mushroom rather than the sticky string. I'd have been more concerned if it was the front wheel or was close to the sidewall. Re: tyre plugs - His Dudeness - 25-05-19 I use the stringy ones and never had a problem but the ones that are a patch and you take the tyre off and pull them through are probably stronger. I'd guess that's what a tyre shop would use
