Starter relay - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Starter relay (/showthread.php?tid=80781) |
Starter relay - Slippy - 13-05-19 My bike wont start! The starter relay has the red cable connected from the battery but the black cable has come loose. Does any one know what bolt size I need to re-attach. Attached a picture to make more sense. Re: Starter relay - Disorderlypunk - 14-05-19 prob an m6/m8 just pop down Wilko's and grab the shortest you can Re: Starter relay - Jules-C - 14-05-19 M6 and about 10mm long. Re: Starter relay - Slippy - 14-05-19 Thanks for that! Have no how it has managed to rattle itself loose Re: Starter relay - Freck - 14-05-19 Just take the one off the red cable, it'll be the same size i bet.
Re: Starter relay - Jules-C - 14-05-19 Disconnect the battery negative lead first to prevent accidentally shorting the positive to the frame Re: Starter relay - Disorderlypunk - 14-05-19 why do i have a feeling that problem took a fair while to find, blaming clutch and stand switches first Re: Starter relay - Slippy - 14-05-19 I had a guess it was the starter relay straight away because it was ticking when the bikes turned on Re: Starter relay - His Dudeness - 14-05-19 Is that a bit of burning on the relay where the bolt was? If the bolt was loose it would cause a bad connection and high resistance and that causes heat and possible burning or arcing. If it is burnt give it a clean. |
