Chain adjusters Grease or not - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Chain adjusters Grease or not (/showthread.php?tid=80768) |
Chain adjusters Grease or not - fazersharp - 11-05-19 I have just removed them and they were gungy with dry grease I have cleaned the up ready to go back but wondering should I grease them or not as they slide in and out of the swing arm no problem but dont want to actually make them slippery because its hard enough keeping things aligned when doing the back wheel up. Maybe just a thin coat of ACF50 Re: Chain adjusters Grease or not - Trebus - 11-05-19 Personally I’d grease them. Had more than one on other bikes seized up. I’d also give the threads on the adjusters some anti seize grease of some description. Re: Chain adjusters Grease or not - bandit - 11-05-19 I agree a light coat of multi purpose grease should be fine on the slider bit. [img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img] Re: Chain adjusters Grease or not - fazersharp - 12-05-19 Thanks for the second opinions chaps. Re: Chain adjusters Grease or not - 10kovako - 12-05-19 I personally have spray on copper grease/ lubricant. Put it on all my bolts as-well and not one has seized! Re: Chain adjusters Grease or not - fazersharp - 12-05-19 (12-05-19, 08:38 PM)10kovako link Wrote: I personally have spray on copper grease/ lubricant. Put it on all my bolts as-well and not one has seized!If you use a torque wrench watch out for the copper grease mucking up your readings. |
