Throttle notch help - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=65) +--- Forum: General (https://foc-u.co.uk/mybb/forumdisplay.php?fid=69) +--- Thread: Throttle notch help (/showthread.php?tid=80754) |
Throttle notch help - Dudeofrude - 06-05-19 I switched over my bars today to flat drag bars and now that I reassemble everything the throttle has a huge 'notch' in it? I cant see what could have changed as it's only an inch lower than it was before? I've tried adjusting the free play using the top adjuster but that doesnt change it It springs back perfect it's just when I'm opening the throttle it seems to catch slightly then release once I apply more pressure It happens probably 8 out of every 10 times I try to open the throttle? Anyone have any ideas what could be up? Re: Throttle notch help - Dudeofrude - 06-05-19 False alarm.... problem solved. Turned out the old cable that used to power the AIS had dropped down and was catching on the throttle body ? Quick cable tie solved the issue |
