Front brake disc mounting face - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Front brake disc mounting face (/showthread.php?tid=80743) |
Front brake disc mounting face - 74eldiablo - 02-05-19 Quick question, ive had my wheels painted the part where the disc mounts does it have to be bare metal or will the painted surface be ok to mount the disc onto? [smg id=3319 18nm front 30nm rear Torque settings Thanks Re: Front brake disc mounting face - darrsi - 02-05-19 I would've thought that bare would be the way to go so you know for sure that the disc is where it should be and straight. Just my opinion though. Re: Front brake disc mounting face - robbo - 02-05-19 Personally I'd take the paint off otherwise the discs will be offset by the paint thickness. Re: Front brake disc mounting face - daviee - 02-05-19 bare metal should have been masked off be careful taking the paint off or you will make the discs sit off set and will act like warped discs Re: Front brake disc mounting face - darrsi - 02-05-19 Whenever i've had my discs off i've made sure that area is meticulously clean, and i mean spotless. Re: Front brake disc mounting face - 74eldiablo - 03-05-19 Thanks for the replies, its now back to bare metal. Hopefully everything will be ok. |
