Linkpipe - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Linkpipe (/showthread.php?tid=80700) |
Linkpipe - Martygg - 18-04-19 Anyone used the fz6 link pipe on an Fzs600? I don't want underseat pipes! Just a high level pipe. Any info would be great. Re: Linkpipe - F4celess - 23-04-19 That would be an interesting, quite original Mod! ...then where would the Silencer part be secured? Alternatively you could go to any decent motorcycle exhaust manufacturer, to make you up a custom length/shaped link pipe - so the silencer sits at the desired new position? Re: Linkpipe - robbo - 23-04-19 I've been running a high level on my thou for a couple of years. Certainly looks different, but as I do trips abroad I need to bolt on pannier frames so have reverted to a conventional look at present. If you can find a motorbike specific exhaust guy, that's the way to go. I fabricated the mount using the pillion peg mounting points but is quite time consuming to get it right. The exhaust guy charged 125 quid including a centrestand stop.If you google Pats Motorcycle Page, there's a pic of his thou with a high level, to give you an idea. Re: Linkpipe - F4celess - 23-04-19 Blue bike. NICE! Infact doesn't look like a drastic change (from the factory configuration/position).
