Ignition Advancer - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Ignition Advancer (/showthread.php?tid=80699) |
Ignition Advancer - Johnnylad123 - 25-04-19 I've bought a 4 deg ignition advancer, but when I've tried to fit it I can't get the bolt holding the original to slacken. I do have an impact driver and an air powered rattle gun but due to it being on the crank end I didn't fancy risking it, what has everyone else used to crack the threadlock?? Re: Ignition Advancer - ogri48 - 25-04-19 heat will debond threadlock mate Re: Ignition Advancer - mickvp - 25-04-19 I’m not recommending you do this, but I just stuck mine in first gear, on side stand, one foot on rear brake and it came loose no bother ? Re: Ignition Advancer - Johnnylad123 - 25-04-19 I tried the in gear and brake method but no joy. I have a heat gun for paint stripping but given there's oil and the electric pickup in close proximity to the bolt I decided against it! Any recommendation as to what heat source would me much appreciated!! Re: Ignition Advancer - unfazed - 25-04-19 (25-04-19, 08:04 PM)Johnnylad123 link Wrote: I've bought a 4 deg ignition advancer, but when I've tried to fit it I can't get the bolt holding the original to slacken.No Thread lock on that bolt (at least there shouldn't be) just 60 Nm of torque. I usually remove the hugger, brush handle through the wheel and rest on the swinging arm, into 4 gear and 1/2 drive and a long breaker bar. Re: Ignition Advancer - ogri48 - 25-04-19 eeeek! all sounds very worrying lol. is the advancer worth it? I tried one on my bandit twelve years back and it actually lost bottom end...been sceptical of em ever since Re: Ignition Advancer - Johnnylad123 - 26-04-19 That's my thoughts now Ogri, it's already cost me a gasket so for all the faff most likely won't do it. Ebay it is! Re: Ignition Advancer - ogri48 - 26-04-19 :thumbup I even had the bandit dynoed at bsd to check, it definitely mullered the bottom end. Though ive read good things on here in the past. I always think my thou has ample bottom (especially after ivanising it) then I jump on me cb1300 and suddenly the thou lump feels like a sports 600 lol Re: Ignition Advancer - PieEater - 26-04-19 Advancer gives a noticeable boost to bottom end and makes cold starting a tad easier, trade off is a slight loss of top end but unless you spend the majority of the time caning the bike the benefits easily outway the costs. Having said that I wouldn't say that it's worth risking engine damage to fit and in this case it's probably best leaving well enough alone unless you take it to a shop to have it fitted and they assume all responsibility ......... Re: Ignition Advancer - Johnnylad123 - 26-04-19 My thoughts exactly PieEater, I reckon the rattle gun would do the trick but at what cost to the bottom end of the motor. Just not worth it I'm afraid. Re: Ignition Advancer - kebab19 - 26-04-19 Providing you have something to balance it on, you could could rest the tip of a soldering iron to the bolt and leave it touching for for 5 - 10 minutes? It would be a more precise way to apply heat to a specific area without risking damage to the surrounding parts. Re: Ignition Advancer - happycallis - 19-06-19 Where does everyone get their advancers from? Re: Ignition Advancer - CatalinU - 10-12-19 Been reading this and thinking myself on changing it. What are downsides of having the 4 degree plate on? Re: Ignition Advancer - PieEater - 11-12-19 (19-06-19, 12:47 PM)happycallis link Wrote:Where does everyone get their advancers from?https://www.ebay.co.uk/itm/Y005-YAMAHA-R1-FAZER-1000-CARB-MODELS-4-DEGREE-IGNITION-ADVANCER-ROTOR-/163660231223 (10-12-19, 05:51 PM)CatalinU link Wrote:Been reading this and thinking myself on changing it. What are downsides of having the 4 degree plate on?Slight reduction in top end power that in real life you will probably never notice. Re: Ignition Advancer - CatalinU - 11-12-19 Ok, will be getting one then. Thanks for the reply Re: Ignition Advancer - ogri48 - 12-12-19 yeah im running one now, I prefer it. along with the ivanising bike starts instantly too. |
