new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark (/showthread.php?tid=80689) |
new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - jackinacabin - 14-04-19 Hi , just bough a fazer , its desided to stop, It ran well yesterday and today will do nothing , Turns over normally but I cannot get a spark so i guess its an electrical issue ... can you knowledgeable folk point me at what tends to cause this with fazers .. Thanks in advance , hope its not a lemon , it was briefly a riot of a ride Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - bandit - 14-04-19 Check the battery voltage, give it a good charge with a bike charger (has the bike been used on a regular basis) as it may be ok to turn engine over but not to spark, you can use jump leads from a car battery if your careful. Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - Fazerider - 14-04-19 Lots of faults can cause a loss of sparks, but quite a lot of them will also prevent the starter motor from running. If you have a multimeter that can help to pin things down. Without one, I’d check connectors are clean and tight everywhere and pay particular attention to the wiring at the rear of the bike near the ignitor unit. If there is, or has been in the past, an alarm fitted then the wiring may have been bodged in that area. On Fazers that haven’t been altered there are a couple of link plugs where the factory immobiliser option can be fitted. If the plugs are corroded or if one of the black wires to them is broken then that will allow the starter to operate, but you’ll get no sparks. Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - jackinacabin - 14-04-19 Thanks for thr replys .... I now have spark back after charging and also checking the plugs around the ecu. When it is light tomorrow I will give the connectors a good clean and spray with contact cleaner ... havent yet started the bike as its late but hipeful it will go - if not its a combinantion of issues - I would much rather tackle a fuel delivery issue than an electrical one so somewhat relieved ... amazing bike when it ran , just so fast compared to my gs 500 ... all the best folks , will post up the results of tomorrows fiddling abouts Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - darrsi - 15-04-19 Where did you buy the bike from, and what sort of mileage? As suggested if it was a private sale it may have been sitting around for a while which tends to play games with the battery, so the bike may need a general service anyway, whereas a bike shop should've given it a full MOT before releasing it. If you plan on doing this yourself then just take one thing at a time and ask away if you need any pointers. Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - jackinacabin - 15-04-19 Hi , the bike was a private sale , its in good shape and has done 28k and was used intermitentely. After charging the battery overnight it started right up so the issue seems to be lower voltage- enough to crank , not enough to spark . I will monitor that battery with a voltmeter , it may well be past its best and need changeing . Also setting up a way to trickle charge the battery every time the bike is parked . I use heated clothing and it also has heated grips so the battery will get a tough life ... maybe I can wire two batteries in parallel as there looks to be room at the back of the seat for another ... certainly a cheaper solution if needed than the high capacity lithium batteries . Thanks for your advice Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - bandit - 15-04-19 (15-04-19, 12:21 PM)jackinacabin link Wrote: Hi , the bike was a private sale , its in good shape and has done 28k and was used intermitentely. After charging the battery overnight it started right up so the issue seems to be lower voltage- enough to crank , not enough to spark . I will monitor that battery with a voltmeter , it may well be past its best and need changeing . Also setting up a way to trickle charge the battery every time the bike is parked . I use heated clothing and it also has heated grips so the battery will get a tough life ... maybe I can wire two batteries in parallel as there looks to be room at the back of the seat for another ... certainly a cheaper solution if needed than the high capacity lithium batteries . Thanks for your advice This is a very popular brand of trickle charger & comes with the lead to connect permanently to the battery as you require as well as crocodile clips to bench charge, the're plenty of cheaper charges around but don't always come with the lead for permanent connection & you will need to make one yourself.[size=78%] Video: [/size] Error 404 (Not Found)!!1 Item: https://www.mdsbattery.co.uk/category-48/accumate-6v12v-battery-charger.html Or just a 12v one slightly cheaper if you don't need the 6v which you may prefer as has more lights to indicate state of charge, also comes with permanent connection. https://www.mdsbattery.co.uk/optimate-2-battery-charger.html Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - Dynspud - 15-04-19 I've been using one of the smaller CTEK ones (XS0.8 I think) for a few years now with no problems:- https://www.halfords.com/motoring/bulbs-blades-batteries/battery-chargers-jump-starters/ctek-xs0-8-battery-charger?cm_mmc=Google+PLA-_-Bulbs,+Blades+and+Batteries-_-Battery+Chargers+&+Jump+Starters-_-280292&istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istItemId=wttaxltt&istBid=tztx&_$ja=tsid:94971|cid:1536900872|agid:58114610145|tid:pla-332616571812|crid:291898455794|nw:g|rnd:6164447258831889849|dvc:c|adp:1o1|mt:|loc:9045650&gclid=Cj0KCQjw19DlBRCSARIsAOnfRejkfYYjlPnlv7drBUT8wayu1jUOqxv2iaI_DPonDCxE-ZxgoMUqproaApWOEALw_wcB Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - jackinacabin - 16-04-19 Thanks , Ive rigged up my oxford charger an oximiser or something like it .... Its doing the trick , just waiting on a lead to make it an easy slick connection when i park ... battery was full but lowish after a short run soi think its seen better days .. I will test with a voltmeter tomorrow to be sure the charging system is doing its job ... Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - fazersharp - 16-04-19 (15-04-19, 04:50 PM)Dynspud link Wrote: I've been using one of the smaller CTEK ones (XS0.8 I think) for a few years now with no problems:-:agree only mine is re-branded as Yamaha and has a car setting. My bike is permanently connected when parked because ic can be weeks at a time between rides. Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - jackinacabin - 16-04-19 Havent checked the volts today as the fiddling on the bike needed to be sorting the seized rear brake ... so , removed the caliper and pistons and seals and reversed the lot then swore a lot while it wouldnt bleed ,,,, eventually its all together and just waiting for new pads and the bike should get an mot Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - jackinacabin - 17-04-19 Well , getting the rear brake to bleed after the new pistons and seals was a right cockwomble but tis done ... all ready for the mot .... next job checking the battery volts after a pootle Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - darrsi - 17-04-19 If you’re fine with servicing your own calipers then depending on if you’re an all year round biker like me it’s worth giving them a scrub with brake cleaner and some fresh red rubber grease twice a year and they will serve you very well. I do mine on the first warm sunny day i have available after winter, then again just before the weather turns iffy before winter. Re: new to me fazer 600 2001 -- ran well yesterday - this morning ... no spark - jackinacabin - 18-04-19 Hi Darrsi , yes , I will do that ... I don`t want to have to rebuild the caliper again in a hurry... Checked the volts and the battery system is all good and holding , possibly simply lack of use had let the battery get low .. all well now .. |
