Top Side Engine bolts - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Top Side Engine bolts (/showthread.php?tid=80674) |
Top Side Engine bolts - Kang - 11-04-19 I am removing the engine bars I got with the bike (ones cracked), do I have to support the engine on the under side to give it support while I remove the bolts? Also I have read some conflicting lines about the torque rating when I go to reset the bolts is there any definite rating? Re: Top Side Engine bolts - Rob R - 11-04-19 If you're talking about the Front Engine Mounting Bolts they should be torqued up to 45Nm (4.5 m.kg, 33ftlb).Do one at a time and you wont need to support the engine.all the bestRob Re: Top Side Engine bolts - Kang - 12-04-19 Cheers :thumbup |
