Starter motor gen 1 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Starter motor gen 1 (/showthread.php?tid=80653) |
Starter motor gen 1 - mickvp - 05-04-19 Alright chaps, starter motor is on its way out (having to rock bike in gear to get it to fire at times). I’ve got a new motor eh route from the bay. Is it a straightforward swap as I’ve not had a chance to look? Re: Starter motor gen 1 - old son - 06-04-19 Looks very easy to me. Two bolts and a cable. Re: Starter motor gen 1 - unfazed - 06-04-19 Unusual thing to go on the Gen 1, have you tried shorting the solonoid heavy duty cables when it happens? Dodgy starter is often mistaken for a dodgy solonoid Re: Starter motor gen 1 - mickvp - 09-04-19 Got a new solenoid on the way unfazed. Will try swapping that out first but both were inexpensive so worst case I bought a part I didn’t need and have a spare ? I don’t think my poor fazer spending winter outside has done it any favours
Re: Starter motor gen 1 - mickvp - 17-04-19 Changed out the solenoid tonight and fired up straight away a couple of times so hopefully that’s all it needed. Can anyone confirm from the manual what amperage of fuse is needed for the solenoid? The one I took out had 30A in but the one I fitted had 20A fuses in it. The battery and starter motor terminals were the wrong way round as well which was a bit of a pain... Re: Starter motor gen 1 - unfazed - 18-04-19 Main fuse in the solenoid is 30 amp on the Fazer 1000. Re: Starter motor gen 1 - mickvp - 18-04-19 Thanks unfazed, I’ll change those out today then
Re: Starter motor gen 1 - unfazed - 18-04-19 Good to see it was a cheap fix. yo caan take the old one apart now and clean the contacts, it will be a handy spare :thumbup |
