sump pan - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: sump pan (/showthread.php?tid=80629) |
sump pan - butthead - 30-03-19 does anyone know if its possible to remove the sump pan in situ without taking the engine out? obviously the exhaust has to come off , but can the pan be removed without engine out ? Re: sump pan - Fazerider - 30-03-19 Yes, it's quite straightforward. Re: sump pan - butthead - 01-04-19 oh good , so have you actually done that? manual suggests engine out, but the chapter wasnt specifically on sump pan removal so i wasnt sure but if you have removed the sump pan in situ with engine still in then thats good news . Re: sump pan - Fazerider - 01-04-19 Yes. Took it off to change the selector forks a few years back. ![]() Are you tackling the same job? Or dropped something in there? Re: sump pan - butthead - 01-04-19 no i was thinking if it was easy to take off and pass through the frame in situ, i can replace the pan with another (inc drain plug ) as a way to resolve the partially stripped oil drain threads than now leak a very small drop. 1/4 teaspoon of oil over 3 days, negligible leak but a replacement pan with bolt is £20 plus the price of a new gasket. Re: sump pan - Fazerider - 01-04-19 Sounds like a sensible solution. Much better than having the plug drop out on the motorway. :'( If time is less of an issue than money you might want to take the sump off before committing to a new gasket… mine came off without damage to the old one. I just smeared a little liquid gasket on and reused it. Re: sump pan - darrsi - 01-04-19 Quite common to over wrench the sump bolt, i will admit to doing it myself. But there's really no need at all, it only needs nipping up. Re: sump pan - butthead - 02-04-19 yeh i blush to confess thats what i did , Mr Haynes states 43nm on the sump plug, not that you can get a torque wrench on the nut due to the frame and sidestand preventing anything other than a ring ( maybe thats why ) , so i lock my torque drive into the vice to feel what 43nm feels like and try to replicate with the ring....... as you say now i know that just a nip is enough, too late :o |
