Wheel Balance Weight Glue - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Wheel Balance Weight Glue (/showthread.php?tid=80610) |
Wheel Balance Weight Glue - old son - 24-03-19 Can anybody suggest a way to remove the sticky tape that holds the wheel balance weights on? Re: Wheel Balance Weight Glue - unfazed - 24-03-19 WD40 and a sharpened plastic scraper always works for me Re: Wheel Balance Weight Glue - celticbiker - 24-03-19 Clutch and brake cleaner. Re: Wheel Balance Weight Glue - robby boy - 24-03-19 petrol and a soft cloth. Re: Wheel Balance Weight Glue - Bubbaad - 24-03-19 Acetone.....AKA.....Nail varnish remover. Re: Wheel Balance Weight Glue - Mustang - 26-03-19 Only thing works is sticky stuff remover or a blowtorch Re: Wheel Balance Weight Glue - old son - 27-03-19 I started at the top of the list of suggestions with WD40 and the edge of my credit card. It worked a treat. Thanks for all of your suggestions. Re: Wheel Balance Weight Glue - Dynspud - 27-03-19 My missus reckons the credit card will solve any problem as well
Re: Wheel Balance Weight Glue - midden - 30-03-19 What about glue for refixing used weights. Re: Wheel Balance Weight Glue - NorthWestern - 30-03-19 Double sided tape does the trick to restick used weights if you have no new ones. You will likely need to reshape them though as they bend a bit when getting them off. Re: Wheel Balance Weight Glue - midden - 01-04-19 (30-03-19, 07:15 AM)NorthWestern link Wrote: Double sided tape does the trick to restick used weights if you have no new ones. You will likely need to reshape them though as they bend a bit when getting them off. Kind of thinking bring back make do and mend society starting with wheel weights
Re: Wheel Balance Weight Glue - Trebus - 02-04-19 Double sided tape or the double sided foam stuff works fine Re: Wheel Balance Weight Glue - silverfz - 03-04-19 brake cleaner and a naked thumb |
