TPO - AIS Removal Kit - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: TPO - AIS Removal Kit (/showthread.php?tid=80585) |
TPO - AIS Removal Kit - old son - 17-03-19 I've got one of these kits. You have to remove the stubs in the head just above the exhaust manifold. Has anybody ever removed these stubs and if you have how did you do it and how hard was it? I know I can put some bolts in and I know I can buy the caps but I want to investigate this first. Anybody help please? Re: TPO - AIS Removal Kit - Falcon 269 - 18-03-19 The stubs can be removed by twisting them out with mole grips. The TPO kit then requires you to drive a ball bearing into the hole to seal it. Personally, I would go the tap and bolt route.
Re: TPO - AIS Removal Kit - old son - 18-03-19 Hi Mike, the ball bearing is retained in a cap that drops into the head where the stubs used to sit. I don’t think access will be great though. Can you remind me of the tap and bolt sizes? Re: TPO - AIS Removal Kit - Falcon 269 - 18-03-19 Ah, I stand corrected, mate. It was many years ago that I last heard of TPO so perhaps their original solution was as I described and they've improved it since then.M8 HSS tapered tap required. 12mm bolt length but it's not critical. Go oversize and cut to length if necessary. Re: TPO - AIS Removal Kit - old son - 18-03-19 Thanks Mike. Re: TPO - AIS Removal Kit - VNA - 21-03-19 I tapped em donkeys years ago. Was fairly straightforward, just took my time. Don’t use a cheapie tap, make sure it’s a pukka quality hardened item. You don’t want a snapped tap in there. Ivan does a kit with a good quality tap, though it’s maybe a wee bit pricey for what it is. http://www.ivansperformanceproducts.com/R1Airkit.htm Re: TPO - AIS Removal Kit - ZiggyCol - 24-03-19 An even more expensive but very neat non-tapping solution is available here . . . http://www.holeshot.com/yamaha/fz1/products/holeshot-racing-air-induction-removal-kit Re: TPO - AIS Removal Kit - old son - 24-03-19 Wasn't somebody on here making these kits some time ago? I think his was similar to the Holeshot kit, no tapping, a cap with a grub screw. Anybody remember who it was, maybe he has some kits left? Re: TPO - AIS Removal Kit - characticus - 24-03-19 I got a set from Justy1 - http://foc-u.co.uk/index.php/topic,512.msg2764.html#msg2764 Don't think he has logged in here for a few years. Re: TPO - AIS Removal Kit - ram - 24-03-19 i have recently got a small lathe and will be making some soon if you want to wait Re: TPO - AIS Removal Kit - robbo - 24-03-19 Stevegixer had a mate who was making the caps about 3 years ago. Had no luck when I tried to get in touch with him last year, so guess he's not on the forum anymore. Re: TPO - AIS Removal Kit - old son - 24-03-19 Thanks for the update. |
