just found some spark plugs !! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: just found some spark plugs !! (/showthread.php?tid=80496) |
just found some spark plugs !! - cl1ve2004 - 23-02-19 came across 2 lots of plugs whilst clearing out garage ngk cr9eix and ngk cr9ek both sets are in great nick ..question..can i use them on my fzs 600 ? cheers clive mash Re: just found some spark plugs !! - darrsi - 23-02-19 Yep, first one is Iridium, and the second one should have a twin prong for a double spark. I have the Iridium's in my bike at the moment, and i have a new set of 'K' version put away for the next change, which could be a long way off yet. Re: just found some spark plugs !! - cl1ve2004 - 23-02-19 Cheers Darssi yep double prong the one set Get em in some time :b Re: just found some spark plugs !! - bandit - 23-02-19 Mine was fitted with CR8E from new so I would only fit CR8E or CR8EIX , changing to a different number i.e 7 or 9 will effect the heat range. See here, also CR8E is the std plug for the U.K. if you live there. / http://www.ngkpartfinder.co.uk/ Re: just found some spark plugs !! - darrsi - 23-02-19 (23-02-19, 03:10 PM)bandit link Wrote: Mine was fitted with CR8E from new so I would only fit CR8E or CR8EIX , changing to a different number i.e 7 or 9 will effect the heat range. See here, also CR8E is the std plug for the U.K. if you live there. You can use 8 or 9 in these bikes, you won't notice any difference. Re: just found some spark plugs !! - darrsi - 23-02-19 http://foc-u.co.uk/index.php?topic=8444.0 |
