Mirrors useless gen1 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Mirrors useless gen1 (/showthread.php?tid=80458) |
Mirrors useless gen1 - Stinka - 14-02-19 all I can see is my shoulders ffs Any mounts to move them out or mirror swaps ? I saw some where cbr1000rr mirrors fit and they looked a bit wider ? Don’t want bar end as they all seem to be that wide I’d have a nightmare filtering in traffic Re: Mirrors useless gen1 - kebab19 - 14-02-19 There's the 'Fuzzyone' mod for the standard mirror setup which works very well, I've done it to my previous and current Gen1. http://www.yamahafz1oa.com/fuzzyonesstockmirrormod.shtml Re: Mirrors useless gen1 - Stinka - 14-02-19 (14-02-19, 07:27 PM)kebab19 link Wrote: There's the 'Fuzzyone' mod for the standard mirror setup which works very well, I've done it to my previous and current Gen1. Awesome! Looks just the trick Re: Mirrors useless gen1 - fatbloke62 - 14-02-19 I had the same issue , I went and got a set of mirrors off a fz1n and a Yamaha clutch perch with the threaded collar off flea bay and removed the standard mirrors and blanked off with some dome head bolts ,happy days
Re: Mirrors useless gen1 - Stinka - 14-02-19 (14-02-19, 08:41 PM)fatbloke62 link Wrote: I had the same issue , I went and got a set of mirrors off a fz1n and a Yamaha clutch perch with the threaded collar off flea bay and removed the standard mirrors and blanked off with some dome head bolts ,happy days Any pics mate ? Re: Mirrors useless gen1 - fatbloke62 - 14-02-19 Pm sent Re: Mirrors useless gen1 - Stinka - 16-02-19 (14-02-19, 07:27 PM)kebab19 link Wrote: There's the 'Fuzzyone' mod for the standard mirror setup which works very well, I've done it to my previous and current Gen1. Just done this. Took 30 mins. Not been out yet but looks spot on sat on drive Re: Mirrors useless gen1 - ogri48 - 16-02-19 nice one. considering it myself mate Re: Mirrors useless gen1 - dickturpin - 20-02-19 I did mine years ago...wou would go back to stick fitting now. Re: Mirrors useless gen1 - Stinka - 22-02-19 So after a few decent rides I can confirm the fuzzyone mod does just what is required
Re: Mirrors useless gen1 - CatalinU - 05-01-20 Is there any spacers that could go under the mirrors and stick them out more? Re: Mirrors useless gen1 - Stinka - 08-01-20 At one time there was spacing blocks available on eBay, not seen them for a while Re: Mirrors useless gen1 - CatalinU - 08-01-20 At the moment can't find anything. Will keep digging
Re: Mirrors useless gen1 - Don71uk - 08-01-20 I have these, https://sw-motech.com/en/bike/YAMAHA/FZS1000/2003/RN06/products/safety/mirror+extension/4052572013465.htm Better than standard, not perfect but you do see more of the road behind. Don. Re: Mirrors useless gen1 - Dynspud - 08-01-20 I've got exactly the same ones as Don on my thou. Just as he says, they aren't perfect but are a good improvement. Also means you keep the adjustability of the mirrors, which you lose if you do the "reverse" mod. Re: Mirrors useless gen1 - CatalinU - 09-01-20 OK, can you guys post a picture of how it looks now. Does the rubber cover works anymore or not? Re: Mirrors useless gen1 - Don71uk - 09-01-20 I’ve tried to post pictures in the past without much luck. The rubber cover still stays on the mirror, the blocks lift the base of the mirror up about 1.5 inches, and the mirrors then sit on top of the blocks. Hope this helps. Re: Mirrors useless gen1 - CatalinU - 10-01-20 Ok, than ks for that, will be considering these an a option Re: Mirrors useless gen1 - castro - 03-02-20 With extenders from SW,fitted underneath standard mirrors with supplied extension hardware,mirrors still fold and use excisting rubber boots. |
