changed header caskets and now no power running terrible srted cheers - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: changed header caskets and now no power running terrible srted cheers (/showthread.php?tid=80457) |
changed header caskets and now no power running terrible srted cheers - psyfi_1 - 14-02-19 Hi guys changed my header gastkets and added the origanal exhuast back on becuase some guy had drilled the exhaust.................... so take it for a test ride and now there seems to be no power........ it is idling fine which i was suprised about Re: changed header caskets and now no power running terrible - daviee - 14-02-19 might be jetted for the other exhaust , or is it just because its quiet making you think its lost power Re: changed header caskets and now no power running terrible - bandit - 14-02-19 The carbs may need to be re balanced. Re: changed header caskets and now no power running terrible - psyfi_1 - 14-02-19 it is quieter but that was to be expected ... but as soon as you put clutch it struggle have to keep it above 5 thousand rpm to get it to move forward other wise it dies Re: changed header caskets and now no power running terrible - psyfi_1 - 14-02-19 and also before i changed exhaust over it was running really rich can start in minus temretures with no choke.... Re: changed header caskets and now no power running terrible - daviee - 14-02-19 put the other one back on see if it goes back to what it was like if it does the quiet exhaust is fooked Re: changed header caskets and now no power running terrible - psyfi_1 - 14-02-19 the one i put on comes from the other fazer i and should have no problems it becuae it was working fine i will put on the other exhuast first see if that changes anything if it does i will change the carbs over i got another set anyways cheer Re: changed header caskets and now no power running terrible - daviee - 14-02-19 could be jetted different for the other exhaust Re: changed header caskets and now no power running terrible - darrsi - 15-02-19 I had my bike jetted once but it never ran right at all to my liking so i had it put back to standard, and it ran fine with any exhaust after that. Unless you're going full on, like using carb pods, then they don't need jetting, but as suggested if it has been altered then it could make a big difference if the original exhaust is put back on. I changed my stock exhaust straight away because i didn't like the look or sound of it, but the bloke who used to Dyno my bike said the stock exhaust headers are better than any aftermarket ones, it was just the build quality that let them down. You don't actually mention if your headers are stock or not? And when you say original exhaust do you mean the headers or the end can? Again as mentioned a carb balance could no doubt help, but also check for any leaks around the gasket area as they can be fiddly and if there is any escaping air then it will markedly affect performance. Something else to bear in mind is the condition of your air filter as well. Any, or even all of these things can make a big difference in running. Re: changed header caskets and now no power running terrible - Fazerider - 15-02-19 The Fazer is fairly insensitive to the type of silencer fitted. Unless a mouse has built a nest in the exhaust I doubt the change is the cause of the problem. What was the weather like when you tested it? The cold, misty mornings we’ve had lately are ideal for carb icing. If the heater passageways through the carbs have become blocked that can give symptoms similar to those you describe. Re: changed header caskets and now no power running terrible - darrsi - 15-02-19 (15-02-19, 01:04 PM)Fazerider link Wrote: The Fazer is fairly insensitive to the type of silencer fitted. Unless a mouse has built a nest in the exhaust I doubt the change is the cause of the problem. Does that heater circuit actually do anything? My pipes were all cleaned out, but if i don't put Isopropyl Alcohol in my fuel over winter it instantly gets carb icing. Been proven year after year so i know exactly how the bike functions without it....shite basically. Mechanic confirmed it as well, and said that chemical treatment would stop it happening. Re: changed header caskets and now no power running terrible srted cheers - psyfi_1 - 15-02-19 okay wasnt the headers i had swapped the coil spade connectors wrong way round..... muppet and im a sparky lol and i did change the carbs to me old bike so that helped with the new exhaust cheers guys for comments it di help |
