R1 Front End Bodywork Issues - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: R1 Front End Bodywork Issues (/showthread.php?tid=80454) |
R1 Front End Bodywork Issues - old son - 14-02-19 I am in the process of fitting an R1 front end and the bottom yoke plate(?) which holds the lower clamps is touching the edge of the fairing. Is this usual and di you just grind away a little of the fairing? It is out of the way and can't be seen. Thanks Re: R1 Front End Bodywork Issues - Falcon 269 - 14-02-19 Never had any clearance issues with the R1 front ends I've fitted, Shaun. What model year forks are you using? Re: R1 Front End Bodywork Issues - old son - 14-02-19 Hi Mike, I am using 1998 - 2002? Its not a serious clash but the lower clamp does rub on the bottom of the fairing. All brackets etc. are straight. It's very strange. Re: R1 Front End Bodywork Issues - Trebus - 14-02-19 Mine was tight but has about 10mm gap from memory Re: R1 Front End Bodywork Issues - Panthor - 14-02-19 Mine rubbed a little bit this was due to the front fairing brackets being slightly bent from a drop. Readjusted then and it’s tight but doesn’t rub now. Re: R1 Front End Bodywork Issues - Falcon 269 - 14-02-19 (14-02-19, 12:51 PM)old son link Wrote: Hi Mike, I am using 1998 - 2002? Its not a serious clash but the lower clamp does rub on the bottom of the fairing. All brackets etc. are straight. It's very strange. Could be that we are using different spacer/steering stem options, mate. Mine was a lot lower at the front and possibly that put the bottom yoke well inside the fairing. Re: R1 Front End Bodywork Issues - Fazerjon - 14-02-19 I’ve put the 2002 5PW front end on mine, no clearance issues at all. |
