EXUP Question - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: EXUP Question (/showthread.php?tid=80413) |
EXUP Question - FazerSimon - 24-01-19 What are the two bolts on the opposite side of the exhaust from the EXUP cover-plate for? They are located behind where the internal bush of the EXUP valve is situated. ![]() Thanks Simon. Re: EXUP Question - old son - 25-01-19 More importantly, you seem to have dripped black paint on your exhaust!! Re: EXUP Question - Falcon 269 - 25-01-19 Daft as it sounds, the bolts are to hold the cover plate and that's all.
Re: EXUP Question - robbo - 25-01-19 Ever wondered why your post got 109 views before any input?. Re: EXUP Question - Decoke Dave - 25-01-19 I must say I thought these cap screws were simply blanking off two access points so that you could put a pin punch in there to drift out the bush supporting the end of the valve if it needed replaced. I did not think there was a blanking plate on there. Re: EXUP Question - Falcon 269 - 26-01-19 (25-01-19, 10:06 PM)Decoke Dave link Wrote: I must say I thought these cap screws were simply blanking off two access points so that you could put a pin punch in there to drift out the bush supporting the end of the valve if it needed replaced. I did not think there was a blanking plate on there. I think you're right. I've never removed them on my bike so assumed that it was a cover plate, too. Access to drift out the inner bush makes perfect sense.
