Renthal low or ultra low? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Renthal low or ultra low? (/showthread.php?tid=80310) |
Renthal low or ultra low? - demic77 - 11-12-18 Evening all, I’m in the process of getting the Fazer (03 foxeye 6) back on the road after a long layup following a back injury. Stock bars are bent after some dozy muppet (me) dropped the bike moving it around the yard to get a load of wood delivered. Which Renthals would be the best for touring/comfort? Seen lots of good reports on the ultra lows but would the low bars be better for comfort? Opinions gratefully received. I’m 5’9” and don’t really want to mess about chopping bar length other messing around with cables etc to fit. Hoping to lead a tour of WW1 battlefields in September 2019 as I know the area, lads from work with everything from Harleys to Gixxers coming along. Want something all day comfortable rather than going for it focused. Stock bars I found ok if a little narrow. Opinions from anyone who’s fitted low rather than ultra low would be much appreciated. Thanks very much, Demic. Re: Renthal low or ultra low? - hopefiendboy - 11-12-18 Hi I have ultra lows on my year 2000 boxeye- slightly lower but noticeably wider than stock. For me these are perfect as I did not have to change any cabling etc. The only point of note is that there are no locating holes in the bars so you have to either drill a hole in the bars or file them off the switch mounts- either way not a problem. I just filed them off and have no problems- preferred doing this over drilling a hole in the bars as then you are not committed to the position and not weakening the bars. Not tried the lows, but a friend who has a Fazer 1000 said he could not fit the lows on due to cable lengths- just anecdotally! Re: Renthal low or ultra low? - F4celess - 11-12-18 You will have some flexibility in the position of the Bars, once fitted, by rotating them towards you or away from you, for optimum reach/seating position. The Renthals are noticeably wider than stock (if you don't cut them down), so you wont be able to filter through small gaps in traffic like before. Renthals also have no pre-drilled holes, like the stock handlebars, that the Switchgear uses to secure into place. You either drill holes into the Renthals to accommodate this, or file down these securing screws, so they only nip tight against the bar to hold in place instead (a short length of tape around the bar at that position can help hold more securely). The quality plus benefit of the Renthals outweigh the above points.. a cheap effective Mod. I also have 'Ultra lows', plus didn't have issues with switch gear cable length. When ordering the 'ultra lows' I expected them to have a more straight (aggressive) profile, however the centre section bends give an intermediate shape, certainly not as extreme as I was expecting them to be. Re: Renthal low or ultra low? - demic77 - 18-12-18 Nice one, cheers for the input. I’ll give the ultra lows a go ?? Re: Renthal low or ultra low? - celticdog - 18-12-18 http://www.beginnerbiker.com/2015/06/renthal-758-ultra-handlebars-review/#.XBifPWj7SUk |
