FS: Yamaha Fazer FZS600 2003 - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: For Sale & Wanted (https://foc-u.co.uk/mybb/forumdisplay.php?fid=80) +--- Thread: FS: Yamaha Fazer FZS600 2003 (/showthread.php?tid=80306) |
FS: Yamaha Fazer FZS600 2003 - Arfa - 09-12-18 Now SOLD. [size=1em]Yamaha Fazer FZS600 2003, in deep metallic purplish blue - the coolest colour of Fazer![/size] [size=1em]Great all round bike, as commuting hack, small tourer or fun blast at weekends. Showing some age, but maintained to a very high standard with all the big service items sorted. It has had a couple of drops but only received cosmetic damage, the majority of which has been repaired to a high standard.[/size] [size=1em]I’m second owner of bike, had it just over 6 years, used it as my daily commute, fun weekend bike, longer distance touring and two-up pillion riding. I’ve kept it in tip-top shape and well maintained throughout, on average putting 8-10k a year on it.[/size] [size=1em]Done 62866 miles (note clocks had to be replaced due to fuel gauge failing, new set show 6k less i.e. 56866). Unlikely to change, as I’ve a new bike for commuting now.[/size] [size=1em]600cc inline 4 giving 95 bhp. Averages 50mpg ish, with a 200-230 mile range before fuel light comes on![/size] [size=1em]Note the 2002-2003 FZS600’s have many advantages over older Fazers: large 21 litre tank, better mirrors (from FZS1000), better looking Fox-eye fairing, better headlights, preload adjustment on forks, better pillion pegs and grab handle and clocks with a clock!.[/size] [size=1em]The good:[/size] [size=1em]Genuine Yamaha double bubble screen[/size] [size=1em]Rear hugger, and front fender extender fitted.[/size] [size=1em]Genuine Yamaha crash bars.[/size] [size=1em]Motad stainless steel downpipes fitted Oct 2013.[/size] [size=1em]Scorpion Titanium exhaust.[/size] [size=1em]Meta M357T alarm/immobiliser fitted. Replaced in July 2013, as internal battery of unit has ~10 year lifespan before it fails. Has worked faultlessly otherwise.[/size] [size=1em]Hagan rear shock fitted Feb 2015[/size] [size=1em]Fazer 1000 ‘blue spot’ rear brake caliper (stock caliper prone to seizing)[/size] [size=1em]Hel braided brake lines front/back.[/size] [size=1em]New Brembo rear disc and rear wheel bearings fitted Aug 2017.[/size] [size=1em]Front wheel bearing replaced Sept 2017. Sprocket carrier bearing replaced Feb 2015.[/size] [size=1em]DID chain sprockets fitted Sept 2017, front sprocket nut replaced as per recall.[/size] [size=1em]Pair of Metzeler M7RR tyres fitted in Aug 2018 (only done ~1000 miles)[/size] [size=1em]Stebal Nautilus air horn fitted, correctly with relay/fuse etc.[/size] [size=1em]Re-upholstered seat, slightly raised, increased hump, more comfort. Original supplied too.[/size] [size=1em]Just had 6k service (oil, filters, spark plugs, carbs balanced etc).[/size] [size=1em]NGK spark plug caps fitted 2017.[/size] [size=1em]K&N air filter - which suits well as runs bit rich from stock. [/size] [size=1em]Coolant system serviced October 2018, O-Ring on thermostat replaced (had small drip leak).[/size] [size=1em]Monokey Givi rack fitted.[/size] [size=1em]Renthal bars fitted.[/size] [size=1em]New clutch fitted Jun 2017, genuine Yamaha friction, steel plates, springs, etc (tried EBC plates briefly before, but were crap). New clutch cable and lever fitted too.[/size] [size=1em]New Yusasa battery fitted in Oct 2015[/size] [size=1em]Forks seals/oil replaced Mar 2015, with genuine seals & dust covers etc. Still good.[/size] [size=1em]Front fairing replaced (with genuine Yamaha part) recently after an incident in 2017, so in spotless condition.[/size] [size=1em]USB socket fitted on dash (auto cuts out when battery voltage drops when engine is off).[/size] [size=1em]Got all paperwork, V5C, MOT history, log book, keys and Meta alarm codes etc.[/size] [size=1em]The bad:[/size] [size=1em]Bike has gone down a couple of times and although has been repaired to a high standard, still has a little cosmetic damage.[/size] [size=1em]Small scuffs and knocks to tank.[/size] [size=1em]Small dent in exhaust.[/size] [size=1em]Some paint lost on engine, radiator and couple of spots on frame.[/size] [size=1em]Cosmetic damage to throttle cable rubber cover.[/size] [size=1em]Clock needed to be replaced as one accident damaged the fuel gauge. Replacement set show 6k miles less than genuine mileage. Original clocks included in sale.[/size] [size=1em]Comes with both keys, but one is a little worn and temperamental. [/size] [size=1em]It’s not perfect, but issues are all cosmetic. Overall a solid well maintained bike that’ll keep on going and delivering many smiles for many more miles.[/size] Now SOLD. [size=1em] [/size][size=1em] [/size][size=1em] [/size][size=1em] [/size][size=1em]Give me a shout if you'd like more pics.[/size] Re: FS: Yamaha Fazer FZS600 2003 - His Dudeness - 09-12-18 Good deal. That'll sell fast
Re: FS: Yamaha Fazer FZS600 2003 - Arfa - 19-01-19 Now sold. |
