FZ1 Gen 2 - rear shock - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: FZ1 Gen 2 - rear shock (/showthread.php?tid=80279) |
FZ1 Gen 2 - rear shock - FZ1obp - 29-11-18 Off to the tip at the weekend - just checking that the old shock of the Gen 2 can't be rebuilt? The spring on it is grey/silver while the 2nd hand replacement I put on the bike about 2 years ago is yellow and a bit harder. Looking in manual I didn't see any spring rate/color charts - any ideas? Many thanks Re: FZ1 Gen 2 - rear shock - Dudeofrude - 30-11-18 The standard shock has a silver spring. As far as I'm aware the spring can be replaced on the standard shock, I just don't think they can be stripped and re-gassed like an aftermarket one Re: FZ1 Gen 2 - rear shock - FZ1obp - 30-11-18 Great - thank you, off to the tip then after removing the spring. Cheers! Re: FZ1 Gen 2 - rear shock - NorthWestern - 30-11-18 You should be able to rebuild/regas the standard shock. I have done it to the std Gen 1 shock, its not a problem. Any suspension place would be able to do it really. Re: FZ1 Gen 2 - rear shock - robbo - 30-11-18 If you give All Bike Engineering a call on 0208 8589052, they'll tell you straight away if it's rebuildable or not. Re: FZ1 Gen 2 - rear shock - FZ1obp - 03-12-18 Thanks for the guidance - all sorted now |
