Ignition Barrel Electrics - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Ignition Barrel Electrics (/showthread.php?tid=80218) |
Ignition Barrel Electrics - Jbizzle - 07-11-18 Hi all, Did the electrics change at all between the FZS 600 models? I am looking to replace the ignition barrel on my 1998 fzs600 and have found a 2003 one on ebay. Will it be a straight swap? Thanks in advance Re: Ignition Barrel Electrics - tommyardin - 08-11-18 (07-11-18, 09:15 PM)Jbizzle link Wrote: Hi all,Yes there is na difference between some of them, I’m sorry I can not recall what the difference is but I believe it’s to do with the number of wires in the bottom of the switches. Follow the link below it will take you to an eBay page the has 1998-2001 switches and switches for the later model of the FZS600’s https://www.ebay.co.uk/itm/Yamaha-FZS600-Fazer-ignition-switch-6-wires-1998-2001-not-for-later-models/272339385858?hash=item3f68b13e02:g:52cAAOSwRH5XKRqS Re: Ignition Barrel Electrics - Jbizzle - 08-11-18 Thanks Tommy, Its for a custom build, i am looking to mount it on the side of the front fairing. do you know if it can be opened up and the steering lock part removed? Thanks again, James Re: Ignition Barrel Electrics - gerkin - 28-11-18 Is the quality of these good looking to replace switch on my 99 model |
