Copies of the Yamaha crash mushrooms: group buy? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: Fazer 1000/FZ1 corner (https://foc-u.co.uk/mybb/forumdisplay.php?fid=75) +--- Thread: Copies of the Yamaha crash mushrooms: group buy? (/showthread.php?tid=80177) |
Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 24-10-18 So as anyone who has been around fazer's for a while knows, getting the official yam accessories like the belly pan and yam branded crash bungs is next to impossible. So as I had low sided my fzs rescently I was just going get a new l/h side made up, but then I thought that maybe we could make this a forum thing and do a group buy and get a bunch of them done all at the same time. Whats say you lot, anyone interested..? Re: Copies of the Yamaha crash mushrooms: group buy? - Ripsnortingvtwin - 25-10-18 i would be up for the group buys if the prices were good , on this one I have them on mine so I'll dip out but thanks Re: Copies of the Yamaha crash mushrooms: group buy? - SkidT - 25-10-18 Having low sided my Gen 1 last November, I could do with one new one as well, so happy to come in if the cost is right? Re: Copies of the Yamaha crash mushrooms: group buy? - Triggergee - 25-10-18 Still need some for my bike so would also be interested if price and aesthetics are right Re: Copies of the Yamaha crash mushrooms: group buy? - GhostCat - 28-10-18 Count me in if the price is right although Im Gen 2 ? Re: Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 31-10-18 Evening Ok once we have a dry & warmish weekend (preferably this weekend) I will remove them from the bike and make detailed measurements and then go about finding a local machine to get a quote. Re: Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 08-11-18 Evening Got the one good protector with an engineering co, 6x pairs to start with will PM everyone who replied once I have them. b. Re: Copies of the Yamaha crash mushrooms: group buy? - SkidT - 08-11-18 Fantastic, thanks Bikerdude. ? Re: Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 08-11-18 On a related note, something I have always thought about these kits was to me the bobbin seemed a bit too stubby compared to the R&G kits. Do we think this was for style reasons over engineering reasons? Where the R&G kits have failed for me a tleast is the large metal block that their bobbins are bolted to, there appears to be nothing sacrificial about that block because when the bobbin wore through and the mounting bolt bent there was no more 'give'. This I'm guessing then transmitted force through to the block, pushing the block which then bent the frame. Now when its on the removable frame rail thats fine but on the side we can't then its potentially a right off. In the same situation the 12mm aluminium base plate of the yam kit just bent in, the bobbin then got pussed up against the engine and then did its job of wearing against the road surface instead of the engine casings. So do we think making the baseplate thicker to 15mm and increasing the height of the bobbin from 65mm to 80 or 100mm would effect the sacrificial way the kits operates..? I only ask because the things this kit as it stands, it dosen't help protect the front fairing, headlight, subframe and infills. We of course have the option then is engine bars, there are few kits (Moto arcs, Swmotech) but only the Renntec appear to be compatible with the yam or other makes of bellypan - they are just butt ugly. Then we have these weird looking bars from Hepco and Becker Re: Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 09-11-18 (08-11-18, 10:46 PM)b1k3rdude link Wrote: So do we think making the baseplate thicker to 15mm and increasing the height of the bobbin from 65mm to 80 or 100mm would effect the sacrificial way the kits operates..? I only ask because the things this kit as it stands, it dosen't help protect the front fairing, headlight, subframe and infills.Spoke to the engineering guy, said increasing the baseplate thickness not advisable, if anything make them thinner. Checking the photo of my bike where it mounts to the frame rail, the plate hasent bent, but rather the bolts did. I am hopping that its just the bolts and not the frame rail, as that will be a right PITA to replace (Ive not seen any of these on ebay - I may just poke 2x long stainless steel bars in the hols and twak the hole back straight. I will check it this weekend if the weather is good enough. Regarding the bobbins, he said there is no reason for them to be taperd, and he says we can have them longer at 100mm up from the current 65mm. Re: Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 03-12-18 Just an update to make you aware that the machine shop is still working on these. Re: Copies of the Yamaha crash mushrooms: group buy? - SkidT - 03-12-18 Thanks for the update Dude. ? Re: Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 24-02-19 This project is still being worked on. Re: Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 12-04-19 Ok so an update on this - The guy who was going to make them closed-up shop, he then gave me the details of another guy who might be able to do it. This second guy then quoted me for them at £80 per set, his reason? the base materials were expensive. So unless I can find a one man band with his own little machine shop this isn't going to happen @£80, we will be better off getting R&G sets which can be found much cheaper online. Re: Copies of the Yamaha crash mushrooms: group buy? - agricola - 12-04-19 I got mine for the FZ6 Fazer from this place, he also made me a set for the axles http://www.jaybeebikerbits.co.uk/index.php/catalogsearch/advanced/result?make=403&model=747&year=421&price%5Bfrom%5D=&price%5Bto%5D=&search= Re: Copies of the Yamaha crash mushrooms: group buy? - SkidT - 12-04-19 No worries b1k3rdude. Many thanks for your efforts anyway in trying to get these sorted. (12-04-19, 07:36 AM)b1k3rdude link Wrote: Ok so an update on this - Re: Copies of the Yamaha crash mushrooms: group buy? - b1k3rdude - 13-04-19 (12-04-19, 08:06 PM)agricola link Wrote: http://www.jaybeebikerbits.co.uk/index.php/catalogsearch/advanced/result?make=403&model=747&year=421&price%5Bfrom%5D=&price%5Bto%5D=&search=You really really do not want to be mounting crash protection, where the part can't transfer any force of an accident into the frame. The yamaha crash kit did its job in 2 ways, the base plate bent talking the initial impact which then allowed the nylon bobbin to do it job as the bike slide down the road. However I also had sliders mounted to the forks and swingarm which are direct-mount and them did there job of protecting those two parts of the bike. (12-04-19, 09:23 PM)SkidT link Wrote: Many thanks for your efforts anyway in trying to get these sorted.I haven't given up, I am still going to try and find a way to make this kit.
