Ahh Coolant leak! - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Ahh Coolant leak! (/showthread.php?tid=80060) |
Ahh Coolant leak! - Arfa - 08-09-18 [size=1em]I appear to have small leak along seal on thermostat (bit below main coolant filler cap under tank). [/size] [size=1em]Pretty certain it's the o-seal on this thermostat. Doesn't appears to originate from the hose or cap. (Cap was new a couple of years ago, as old wasn't holding pressure). On pressure testing the system, I get a a few small drips forming at the base of thermostat only. Anyone done this job of replacing and dismantling the thermostat? Any tips, tricks or advice?[/size] [size=1em]Bit worried the attached hoses aren't going to like this job, as they're looking pretty old and flakey. And still we haven't sorted out any silicone hose group buys... :eek [/size] [size=1em]Anyone had any joy buying random silicone sections and bends to replace some of the hoses on the FZS600? For example: [/size] [size=1em]http://www.jsperformance.co.uk/silicone-hoses/elbow-silicone-hoses/30-degree-elbow-silicone-hoses[/size] [size=1em]Do we have any knowledge on what bends might cover what bits of the system?[/size] Re: Ahh Coolant leak! - His Dudeness - 08-09-18 Yes it's leaking from the o ring in the middle of the thermostat. The hoses should be fine. New o ring and coolant and it should be sorted. It's an easy fix. Get the part number from the part number manual in the download section. Re: Ahh Coolant leak! - bandit - 08-09-18 As His Dudeness said you should be able to split the housing by removing the three bolts without touching the hoses. https://www.wemoto.com/bikes/yamaha/fzs_600_fazer/98-99/picture/thermostat_housing_o_ring Re: Ahh Coolant leak! - Jules-C - 09-09-18 And don't overtighten the bolts because half the housing is plastic. The official service manual has the wrong torque settings Re: Ahh Coolant leak! - Arfa - 09-09-18 (09-09-18, 10:40 AM)Jules-C link Wrote: And don't overtighten the bolts because half the housing is plastic. The official service manual has the wrong torque settings My Haynes book quote 10Nm - sound about right? Though TBH not sure I'll get torque wrench in there without removing all hoses and pulling lot out. 10Nm sound about hand tight anyway. Re: Ahh Coolant leak! - Jules-C - 10-09-18 That's what official manual says Haynes probably copied. I think I did mine about 6Nm you only want to crush o'ring slightly |
