Breather? - Printable Version +- Fazer Owners Club - Unofficial (https://foc-u.co.uk/mybb) +-- Forum: Bikes, Hints'n'Tips (https://foc-u.co.uk/mybb/forumdisplay.php?fid=66) +--- Forum: FZS600 Fazer (https://foc-u.co.uk/mybb/forumdisplay.php?fid=78) +--- Thread: Breather? (/showthread.php?tid=80008) |
Breather? - deeteefifty - 26-08-18 Hello, I removed the carburettors to free off a seized tick over adjuster and on strip down noticed the item marked with a green arrow, should connect somewhere or does it vents to atmosphere? Re: Breather? - bandit - 26-08-18 It vents to the atmosphere..[img alt=Smile]http://foc-u.co.uk/Smileys/efocicon/smile.gif[/img] Re: Breather? - deeteefifty - 26-08-18 Ta very much bandit for your quick reply? Re: Breather? - Fazerider - 27-08-18 As Bandit says, it doesn’t attach to anything else. It looks twisted out of position in your photo though, it normally faces backwards: which might give that wiring it’s pressing against a bit more room. Re: Breather? - deeteefifty - 27-08-18 Ta fazerider. I've a bit re routing to do, the clutch cable has a sharp bend on its way from the frame top tube then behind the side cover, but maybe there's no choice with that one. Re: Breather? - Fazerider - 27-08-18 If you think a previous owner may have messed things up there’s a diagram for cable routing in the manual (available in the downloads section). Re: Breather? - deeteefifty - 28-08-18 Thanks, found it and things aren't too far off. The tight bend in the clutch cable from frame top tube to casing looked suspicious but surprisingly this matched with the diagram? |
